Thread: Brake light switch replacement A3 1998
  1. Brake light switch replacement A3 1998
    Sep 2009
    Cheltenham
    Hi there,
    If anyone has ever changed it, do you have a simple procedure to follow?
  2. Re: Brake light switch replacement A3 1998
    a6rom Guest
    1) Remove the bottom panel underneath your dashboard (if needed)
    2) Push brake pedal down
    3) Remove sensor electrical clip
    4) Remove brake light switch by turning it 45 degrees to the left and pulling it out
    5) Let go of brake pedal
    6) Prep the sensor: make sure the plunger is pulled out fully (extended OUT) *warning* Make sure you do not push the plunger in at any time.
    7) Here's the new step: Do not depress pedal as far as you can. Leave the pedal in it's normal position and push the brake light switch into the mounting hole.
    8) You will hear several "clicks" which is essentially setting up the length of your plunger to the pedal. Turn the brake switch 45 degrees to the right to enable the "setting" for your brake. There is a tiny rotating part that activates the setting on your switch when you rotate it.
    9) This is ONE time deal so if you mess up do not pull the plunger out to try again.
    10) Install the electrical plug
    11) Check brake lights, the lights should come on with very little brake pedal movement. If you need to depress the brake a lot in order for the lights to come on, you have done the "setting" part incorrectly. There's no fix for this, you'll have to get an exchange for a new part if they'll let you.
    Overall this is an easy install but can be annoying because of the one time setting deal.
    Hope this helps!
  3. Re: Brake light switch replacement A3 1998
    Oct 2019
    Walsall
    Is there diagrams anywhere to show this as I cannot find this switch anywhere
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  3. Please Help Green brake light switch
    By JayWorm in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2009, 04:45 PM
  4. Audi A4 Brake light problem
    By agriffiths in forum Archive posts
    Last Post: 22-12-2006, 02:10 PM
  5. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
