Thread: Another strange temperature problem!
  1. Another strange temperature problem!
    Sep 2009
    bristol
    HI guys ive got a 99 1.9 tdi AHU the problem is that when i turn on the ignition without cranking the engine the temp gauge flicks straight to 80c with the engine stone cold! if i then start the engine and leave it to idle it slowly reaches around 90c after 10-15 mins which sounds ok, then if i drive it within about 5mins the gauge reads upto 110c! and will then stay there, i thought maybe a coolant sensor problem so i disconnected it and turned the ignition only to find the gauge still flicks straight to 80c when cold. im stumped im not sure if the car is overheating or im just getting a false reading, Any ideas?
  2. Re: Another strange temperature problem!
    Sep 2009
    bristol
    ok so i just replaced the temperature sensor and its made no difference at all
    im very confused now please someone help me!
  3. Re: Another strange temperature problem!
    Southern County Softy
    20 Post(s)
    Gauge failing, you can send your ash away for testing and repair.
    http://www.bba-reman.com/uk/index.aspx
    A4 2.5 tdi QS (mapped)
  4. Re: Another strange temperature problem!
    Sep 2009
    bristol
    ok kite thanks for the advice ive been sifting through the forum and it sounds like quit a common problem, it looks like mine is just reading 20 degrees higher than the actual temp.
  1. Question Strange cluster problem
    By Copiertech in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2009, 03:01 AM
  2. Very Strange Problem
    By coachcabe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-11-2007, 05:31 AM
  3. Climatronic Diagnostics
    By milenia in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-09-2007, 10:17 AM
  4. Central lock problem Passat 1.8T 2000
    By tjompen1968 in forum Archive posts
    Last Post: 19-09-2006, 09:37 PM
  5. Central lock problem
    By tjompen1968 in forum Passat - Archive Topics
    Last Post: 19-09-2006, 09:36 PM
