Thread: Hissing Noise
  1. Hissing Noise
    Sep 2007
    Liverpool
    Passat 2003 1.9 tdi
    After driving usually 20 miles+ when I get out of the car I can hear a hissing noise it appears to come from the very back of the engine compartment / bulkhead on the drivers side. Any help or advice would be greatly appreciated.
  2. Re: Hissing Noise
    Jun 2006
    UK, Mids
    Probably just refrigerant hissing through the pipes and valves as it settles down and equilibrates?
    Audi A8 - 2015 - 3.0TDI
  3. Re: Hissing Noise
    Dec 2008
    Does it happen when the aircon is turned off? I had the same thing happen with my motor. It dosnt happen if aircon is turned on economy or turned off. Havnt had any problems because off it and its happened since i bought the car.
  4. Re: Hissing Noise
    May 2006
    Its the Aircon system pressure equalising when the engine driven compressor stops when you switch the engine off. Best thing for the system is to turn it to ECON about 1 mile from your destination, this will turn off the compressor and ensure all gas / oil is in the correct place when you do switch off the engine & no hissing...
    (I do aircon for a living..)
  5. Re: Hissing Noise
    Tyldesley, Manchester, UK
    As already mentioned the A/C.
    One German, Two Italian.
  6. Re: Hissing Noise
    Gwent
    Another possibility is a vacuum leak, the vacuum system includes the servo and control pipework for the turbo boost control and EGR control
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  7. Re: Hissing Noise
    Sep 2007
    Liverpool
    Quote Originally Posted by scotty33 View Post
    I have also noticed that the car does not seem quite so gutsy, as I had it remapped a couple of years ago. All was fine at first but now dont seen to get the same performance. I have fitted a new MAF, temp sensor and recently injector loom, any suggestions would be appreciated.
  1. 2.5tdi hissing noise
    By nanafagis in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2009, 10:32 PM
  2. Please Help Hissing noise in engine bay.
    By soulstyler in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2009, 07:44 PM
  3. hissing type noise when accelerating
    By bll2109 in forum Golf MK4 - 1999 - 2004
    Last Post: 19-02-2008, 02:21 PM
  4. mk4 gt tdi 130 turbo hissing noise - wastegate?
    By leemasiuk in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2007, 06:53 PM
  5. Intemittent loud noise from radiator area
    By TBird1 in forum Passat - Archive Topics
    Last Post: 09-02-2007, 03:20 PM
