Thread: Help/advice please - climate control unit part nos.
Results 1 to 10 of 12
  1. Help/advice please - climate control unit part nos.
    Bracknell, Berks
    Hi all
    I have a 1996 A4 Avant that has the dreaded climate control issue (display panel & buttons only working when they feel like it).
    I've hoiked the unit out to get the part number, and the label says:
    5HB 006 500-11
    8DO 820 043 H
    There are are fair number of visually identical units on eBay, but none match the above exactly. Closest I've seen is:
    8D0 820 043 F
    from a 1995 car.
    There are a number of slightly later ones e.g.
    5HB 007 608-04
    8L0 820 043 D
    and
    5HB 007 608-00
    8L0 820 043 B
    both from 1997 cars.
    So the question is ... how 'universal' are these units?
    Many thanks in advance for any advice!
    Cheers,
    Bill
  2. Re: Help/advice please - climate control unit part nos.
    Southern County Softy
    20 Post(s)
    8L ones are from A3's
    A4 2.5 tdi QS (mapped)
  3. Re: Help/advice please - climate control unit part nos.
    Bracknell, Berks
    Thanks. Would they work in an A4?
  4. Re: Help/advice please - climate control unit part nos.
    Bracknell, Berks
    Most of the ones on eBay seem to be advertised as "A3/A4".
    This is an 8L one that's supposedly from a 1999 A4
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
  5. Re: Help/advice please - climate control unit part nos.
    Jul 2008
    stoke on trent
    you need to match the part number to be sure!
    8d0/8l0 refers to the chassis of the car they where designed for but there are many parts that are shared between the audi range e.g radio starts 4b0 which means its an a6 part but its fitted to all models, so the 8l one could of come from an a4, if the 3rd digit isnt a 0 its more likely model specific, 8d5 would mean a4 saloon part only 8d9 a4 avant only
    just because it looks the same doesnt mean it will work, ive tried swapping a later one into an earlier one and the illumination worked back to front and it wouldnt switch the a/c on
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  6. Re: Help/advice please - climate control unit part nos.
    Bracknell, Berks
    That's very helpful, thanks. Must be a fairly slim chance that exactly the right one will come up?
    I found this excellent thread with pics on a US forum:
    http://www.audiforum.ca/general-d-i-...4-climate.html
    I'm ok with a multi-meter and electronic soldering so might take it apart and try re-soldering the joints. I'm assuming a new unit from a dealership is going to be about the same as the car is worth?!
  7. Re: Help/advice please - climate control unit part nos.
    Oct 2009
    buckingham, buckinghamshire
    i got one from fleabay..part numbers didnt match..but it tried it anyway..and it all works fine....
    was advertised as fitting a3, a4 ,and a6
  8. Re: Help/advice please - climate control unit part nos.
    Bracknell, Berks
    Well I decided to have a go at repairing the unit.
    Taking it apart was straightforward, and under close examination I found 3 or 4 cracked solder joints as per picture below.
    I resoldered all of them and had it back together in not more than 30 mins.
    Back in the car ... the display was now perfect, and all the buttons worked.
    BUT the blower (fan) doesn't run at all, in auto or manual mode
    So will try a few searches to see if I can dig anything up on that.
  9. Re: Help/advice please - climate control unit part nos.
    Bracknell, Berks
    OK sounds like it could be the blower motor/brushes. Some of the 'how to' threads don't seem to exist any more, but sounds reasonably straightforward through the glovebox.
  10. Re: Help/advice please - climate control unit part nos.
    Definitely sounds like the blower bushes are u/s, someone sells them on E bay for about £12 and its only an hour or so to strip out the motor and sort them .
  1. Just fitted new climate control unit - ECON light has come on?
    By pds999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-01-2010, 11:06 PM
  2. Question Replacement drivers window control unit
    By ally0000 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-08-2009, 11:37 AM
  3. Activating cruise control 2003 Audi A4 sport 1.8T BEX 190 bhp
    By andythechief in forum VCDS - Help Requests
    Last Post: 13-06-2009, 04:25 PM
  4. auto shutdown of convenience systems
    By bigb in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 29-03-2009, 07:40 PM
  5. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
