Thread: How to
Results 1 to 8 of 8
  1. How to
    Feb 2009
    I'm trying to remove my front bumper (PASSAT TDI 2001) and have removed all the screws as given in the Haynes but cannot get it to "release" from the car: do I have to pull, push or lift to remove it from the guides: I'm worried that I might break it?
  2. Re: How to
    pull it towards you , if you have all screws removed , did you take the wing liner screws out , if its stubborn have someone palm the edge of bumper nearest the wing arch as you pull . this is the only area really that sits on a plastic runner both sides.
  3. Re: How to
    Feb 2009
    Thanks, it came off fine: I am chasing a small oil leak and wanted access so see if I could find the leak. I think a small amount of oil is getting onto the fan and this spreads it around the area behind the headlight.
    Even with the bumper off I cannot see an obvious cause of a leak: I just tightened a pipe clip around the turbo hose but eveything else looks like push fit. Ive just given the area a good wipe and will have a look later to see it the leak shows itself; probably won't without the engine running.
  4. Re: How to
    Check the intercooler isnt full of oil , 1 on the right side looking at the car , those pipes attatched to it usually fill with oil and begin to drip , this is lower down though than the fan so im at a loss , defo check all intercooler to turbo pipes though and give them all a good clean out.
  5. Re: How to
    Feb 2009
    Thanks - I'll have a look but space is so tight around that area: I'm having a VW dealer do all three belts on 7/Dec so I might ask them to drain the turbo pipes while the Lock is pulled forward. The price is about £304 including VAT, which is cheaper than my local do everthing garage: expensive for a Timing belt but at least the EMC should be setup correctly with their VW equipment.
  6. Re: How to remove front bumper 2001 passat
    Having same worry as TEEMMERT - all bolts removed but unable to "release the ends of the front bumper from the guides ... " as Mr Haynes might say. Pic in Haynes isnt great but looks like the bumper probably ought to slide forward (ie, normal direction of travel) to disengage from the guide . Noticed that "passat 130 TDi" says pull towards you - I think that that means try to slide bumper forward to front of car (not to pull edge of bumper at right angles to car) . Am I right ?
    Trevor
    PS might need to move car a few yards to somewhere drier tomorrow - any reason why I should nt move it with bumper removed ?
  7. Re: How to remove front bumper 2001 passat
    Quote Originally Posted by trevMk2 View Post
    Trevor
    Bang each corner under the wheel arch with the palm of your hand towards the radiator , it will soon pop off the plastic runners, its only road dirt holding it in place if all bolts are removed.
  8. Re: How to remove front bumper 2001 passat
    Feb 2009
    It took a stong yank forward to remove my bumper: I had some sealant around the headlights that may have added to the problem.
