Thread: Frost and window drop
Results 1 to 10 of 12
  1. Frost and window drop
    Sep 2007
    Scotland
    Well winter is on it's way in case you hadn't noticed.
    And as the owner of a previous frameless windowed car I just want to know if anyone has any tips or tricks in how to deal with an iced up window drop?
    What I used to do with my Astra Coupe was to wet a finger and run it along the bottom of the window at the seal which cleared enough space for the window to drop down. This worked for the first two winters but by the third, as seals and runners started to age, I had some nervous mornings where the window refused to drop and had to be pryed from the seal as the door opened and one or two where the door and glass were stuck fast and I had to revert to warm water.
    First thing to do in the CC is obviously to change the courtesy settings so that only the drivers window drops when the car is unlocked, but does anyone know of any silicon sprays or something which will keep the rubber supple without ruining it?
    Your thoughts please.
    BMW 530d Sport 3.0 TDi 192PS
    Passat SE 2.0 TDi 140PS PD
    Passat CC GT 2.0 TDi 170PS CR
    Audi A4 Avant Black Edition 143
  2. Re: Frost and window drop
    Oct 2009
    Hampshire
    Yikes frost already. You should move to Hampshire to solve the problem as we don't really expect frost for a few more months yet
    Anyway I see what you mean about the elevator windows getting mightily upset when they can't "conveniently" open an inch to let you in.
    Personally I have used Rain X for years on all the glass round the car and this seems to deter frost as well as rain, although doesn't solve it. Makes sense in that if you can make the glass as slippery as possible the water will slide off, especially on the sides so there is less to get frozen.
    Failing that I guess it's gonna be a case of climbing through the boot. Oh the indignity of it all.
    Shadow CC
  3. Re: Frost and window drop
    apply some vaseline on the door seal will help . worked on both my celicas.
  4. Re: Frost and window drop
    Chester-le-Street, United Kingdom
    perhaps a thin smear of vasaline along the inside of the seals?
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  5. Re: Frost and window drop
    great minds?
    4th cog,--two to go
  6. Re: Frost and window drop
    Oct 2009
    Hampshire
    isn't that the same Vaseline which is rNOT ecommended to be used with certain er, um, rubber products as it rots them????
    Shadowy CC
  7. Re: Frost and window drop
    Quote Originally Posted by STEWY L View Post
    regards,
    stewy.
    Quote Originally Posted by Shadow CC View Post
    Shadowy CC
    probably,but we're not doing that
    it seals sunroofs too
    regards,
    stewy.
    4th cog,--two to go
  8. Re: Frost and window drop
    great minds?
    well us north east lads are pretty clever.
  9. Re: Frost and window drop
    Sep 2007
    Scotland
    It appears that you can't disable the window drop in the Convenience Menu.
  10. Re: Frost and window drop
    Canada
    Shadowy CC
    get some silicone grease, it wont damage the rubber, but something like autoglym bumper care may be good , a small amount in groove would do the trick
  1. Steamy windows
    By Vic Young in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2009, 10:50 PM
  2. Electric window not working
    By jacoeras in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2008, 10:55 PM
