Thread: 91 200 Q 20v Turbo Cuts power when WOT under boost
  1. 91 200 Q 20v Turbo Cuts power when WOT under boost
    Oct 2009
    Portland, OR
    I'm new here. my name is Ernan, i live in Portland, OR USA (born and raised in Bosnia, Europe)
    I just bought 91 200 Q 20v turbo 5 speed sedan with 226k miles.
    For some strange reason, when i start boosting under WOT 3/4 and up of gas pedal, something past 2500rpms engine hesitate and lose all power, looks like you hit rpm limitter, but if i dont hammered all way down i could get to 7000rps, it also reving find on idle but thats because turbo is not making whole a lot of boost since there is no load, also if i disconnect battery for min or two, hok up battery and take for a spin, it will go fine under boost and WOT for a few runs and it will start acting up
    I have pulled spark plugs, they all working, little bit on lean side but not much its still gray color
    So to me it looks like ECU is pulling timing, cutting fuel since i hear pining
    Meybe is one of sensors, TPS, Crank, of cam shaft sensor, or even knock sensor if this Audi have one
    BTW after i gat 200 running, engine/tranny will be swapped into my 90 Coupe Quattro
    Im sorry for my english, it bad i know
  2. Re: 91 200 Q 20v Turbo Cuts power when WOT under boost
    Long Beach, California, USA
    I had same problem w/ '89 200 turbo: full throttle invoked engine shutdown for 2-5 seconds.
    The mechanic found that the tubocharger wastegate diaphram was broken, he found the part for $150. From what I understand, this fault was also affecting the low-throttle operation, stressing the intake and possibly leading to head gasket problems, by allowing too high a pressure at nominal operation.
  3. Re: 91 200 Q 20v Turbo Cuts power when WOT under boost
    Gwent
    Hi some good information on this site:
    http://www.sjmautotechnik.com/troubl.../20vboost.html
    suggest you start by reading the ECU fault codes?
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. Loss of power in 1.8 20v non turbo
    By mcracknell in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-07-2016, 09:18 PM
  2. Mark 4 Golf TDI (90) Turbo cuts out
    By Pierre in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 08:04 PM
  3. VW PASSAT 20V Turbo - Wont start first time :(
    By DUbDUb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-03-2008, 01:23 AM
  4. Turbo/lacking Power
    By kentwagen in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-02-2008, 08:16 PM
  5. Max boost for a KKK K14 turbo?
    By DubDick in forum Archive posts
    Last Post: 04-09-2007, 08:34 PM
