Thread: 1.9 TDI loss of power in the wet
Results 1 to 10 of 11
  1. 1.9 TDI loss of power in the wet
    May 2008
    Hi all
    First of all apologies if this has been covered elsewhere (couldn't find a thread).
    My A4 1.9 TDI has a habit of acting strangely in the wet. When it is raining/roads are still wet the car loses power and begins to splutter, almost mis-firing. Once the car has dried out the problem stops and the car returns to normal.
    Anyone any ideas what the problem could be?
    Thanks in advance.
  2. Re: 1.9 TDI loss of power in the wet
    Nov 2008
    Huntingdonshire
    I would start by checking the chamber where the fan and battery sits for blockages and check the passangers foot well for dampness (remove the passanger before hand).
    Take the engine cover off and do a general check on any electrical connectors you can see.
    Use or find someone with a ODB code scanner like VAGCOM and do a diagnostic check.
    If any sensors are being grounded / shorted by the water this should be logged.
    Check the alternator connections too.
  3. Re: 1.9 TDI loss of power in the wet
    May 2008
    Quote Originally Posted by Camb-Tech View Post
    Thanks for the suggestions. I'll try all of the above.
  4. Re: 1.9 TDI loss of power in the wet
    Check the air filter housing for water ingress
  5. Re: 1.9 TDI loss of power in the wet
    I had the same problem, I had a cracked maf sensor connector, I used some switch cleaner and some dielectric greese " dow corning4 " to prevent moisture ingress on the connector, Problem has never come back ever since.
    Hope this helps, It does sound like the same problem.
  6. Re: 1.9 TDI loss of power in the wet
    Aug 2007
    Newport, Wales
    7 Post(s)
    I suspect it will be something to do with the electronic measurement of air (as nutter suggests - the MAF).
    It won't be ignition related and I doubt it'll be fuel related (unless the electronics for the fuel delivery system are getting wet - but more likely to be air related).
    One other possibility... the 1.9 is a little underpowered for Quattro in my honest opinion and the engine does bog-down when driving all 4 wheels! (maybe I've been spoilt by previous cars!) Is yours a Quattro?
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  7. Re: 1.9 TDI loss of power in the wet
    Oct 2009
    Wiltshire England
    I would give all the electrical connectors a check over like the MAF sensor, good advice to check the ecu tray too, but take care I think you need to remove the wiper arm to get in on all of the lid fixings.
    I understand the wiper arms go brittle after time and can snap off, it happened to a friend, try a bit of wd40 the day before on the splined shaft to help free it up.
    good luck
  8. Re: 1.9 TDI loss of power in the wet
    May 2008
    Quote Originally Posted by nutter1980 View Post
    Thanks for your reply.
    As i am very much the amateur mechanic i have a few questions.
    Did you remove the sensor then clean and seal it? or did you leave it on the car?
    How much grease did you put on it? (ie. did you cover it in the stuff?)
    Can i do any damage if i screw this up???
  9. Re: 1.9 TDI loss of power in the wet
    Quote Originally Posted by elliottj View Post
    Hi, It so easy, I am not a mechanic.
    To solve my problem I simply unplugged the cable connected to the maf sensor sprayed in some switch cleaner, reconnected and disconnected afew times.
    That cured my problem. I added the dielectric grease afew weeks later, you dont have to use it, it just ensures good electrical contact and keeps away moisture.
    Ohhh and dont use silcon seal !! Do not use Silicon seal !! Do not glue the connector into the socket...
  10. Re: 1.9 TDI loss of power in the wet
    ninotschka Guest
    \mine had the same problem about a year ago. It turned out to be the air mass meter , cost me around £70 to have it fixed by an Audi Specialist (not a dealer)
    Good luck!
  1. A6 1.9 Tdi Lack Of Power
    By senator in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-01-2010, 12:47 PM
  2. Power loss problem with 1997 A4 1.9 TDI
    By john davis 100 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-10-2009, 08:52 AM
  3. 1.9 TDI 110 Running rich and power loss
    By joe406 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2009, 05:46 PM
  4. TDI Sudden Power Loss! Later higher MPG?
    By TDI-3 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 05:32 PM
  5. Replies: 0
    Last Post: 20-07-2006, 09:08 PM
