Thread: coolant system circulation
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
  1. coolant system circulation
    Jan 2008
    nottinghamshire
    hello all
    i have a 1.9 tdi 115 and i could do with some of your ideas
    i have a problem with the circulation of the coolant, i think its an air lock but i also think i may have a blockage and thats why i cant get the air out..
    sometimes the heater drops cold, and when you check under the bonnet the top hose is hot along with a few other and bottom hose getts slightly warm at the top
    from what i can feel the rad gets hot but not sure if this has a blockage as i cant seem to get this air lock out
    after a run the bottom hose still doesnt get warm all the way down just still at the top and the expansion cap hisses air slightly
    it never over heats but it has crept up over 90 degrees a couple of times when i peg it down the dual carrage way
    i have had a sniffer test so its not the head gasket
    i have had a cap fitted
    i had a slight water leak but now fixed
    not sure exactly what is wrong with it, i have a feeling its the rad thats blocked, cause ive never heard the fan switch cut in and the fresh coolant thats was put in recently has now turned a bit rusty coloured
    anyway please help cause i dont want to get head gasket problems from a stupid air lock
    thankyou
  2. Re: coolant system circulation
    Pembrokeshire
    22 Post(s)
    water pump, i think. these are self bleeding, so shouldny air lock. incidentally, the sniffer test( blue fluid that turns green/yellow)are unreliable on a diesel. if it does change colour, you have a blown gasket, if it doesnt change, it means nothing.
  3. Re: coolant system circulation
    Southern County Softy
    20 Post(s)
    As Zollaf says waterpump, these are known to fail, also a good idea to change the stat
    A4 2.5 tdi QS (mapped)
  4. Re: coolant system circulation
    Jan 2008
    nottinghamshire
    ok if you guys are sure ill go for that
    is there anyway to tell for sure or is it trial and error..
  5. Re: coolant system circulation
    Southampton, UK.
    My money is on the waterpump. There have been previous posts on the forum regarding the heater blowing hot and cold and it's been just that. The coolant isn't getting pushed round the system properly, hencte the hot & cold heater and dodgy rad.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  6. Re: coolant system circulation
    Jan 2008
    nottinghamshire
    thanks for the replies
    appreciate it...
  7. Re: coolant system circulation
    Jan 2008
    nottinghamshire
    swapped the pump but the old one was fine
    anyone got any more idea's
  8. Re: coolant system circulation
    Jan 2008
    nottinghamshire
    ended up being the thermostat
    i was under the impression the thermostat was in the top of the top hose because the top hose got hot first
    i didnt know until today it was in the bottom hose, i would of thought that anyone who knew that the thermostat was in the bottom hose would have pointed me in that direction first as the bottom hose only getting slightly warm at the top would have been a big indicator that the thermostat was blocked shut
    so if your bottom hose doesn't get hot and your car overheats when going fast try your thermostat, it may not be water pump or head gasket like everyone assumes
  9. Re: coolant system circulation
    Southampton, UK.
    Thanks for pointing that out. Kite did suggest the 'stat', though like you and without consulting a Haynes manual, I would have assumed it was in a top hose too. We live and learn.
  10. Re: coolant system circulation
    Jan 2008
    nottinghamshire
    i still have problems
    sometimes the bottom hose gets hot but sometimes its stone cold
    i think the thermostat housing maybe shot as i dont think the thermostat fitted in securley when i fitted it
    and sometimes the heater fluctuate from warm to cold, they never really gett hott like my other tdi
    just to let you know ive had a
    thermostat
    water pump
    expansion cap
    pressure test
    sniffer test
    i have a feeling i have a blockage or something simular, like radiator cause the coolant just doesnt seem to flow around like it should
    any help appreciated
    thanks for reading
  1. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  2. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  3. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
  4. The performance SUV Audi Q7
  5. The new Audi A6 Avant
