Thread: Code 16804- warning light comes on but no fault?
  1. Code 16804- warning light comes on but no fault?
    Mar 2007
    Warrington, Cheshire
    Hello
    Can anyone help with a persistent problem with my Audi A4 2.0 2002.
    The engine management system warning light keeps coming on. I have reset it with my handheld but it still happens. The DTC displayed is 16804?
    I have taken it to an approved mechanic three times now with the same problem and although the first time the lambda sensor was change after a couple of days the warning light still comes on?
    After the first time , the mechanic has said he can find no faults and does not recognise the above code? He has also had an auto electrician to check the wiring and to do a road test but still no cure
    This is all new to me , so any help would be appreciated.
    Canada
    The fault is due to the lamda/oxyegen sensor look here
    http://wiki.ross-tech.com/index.php/16804/P0420/001056
    it need to be chaged as is probalbly gone faulty, they can cause other fault code to appear (lean mixture/misfiring etc) but theese should go once done.
    They cost around £80 to £100 pounds depending on the type installed.
    Rob
    Mar 2007
    Thanks for the quick response Rob.
    when i looked on the net for this problem , they all directed me in this direction but the Lambda sensor was the original fault when i first took it in. They said that this had been changed? It was done about 8 months ago?
    Could it have gone faulty this soon?
  1. Fault code
    By philglasgow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 08:41 PM
  2. Fault code reader
    By paddymm in forum Audi A4 - Archive Topics
    Last Post: 02-04-2007, 10:31 AM
  3. fault code reset?
    By JELLYBEAN in forum Archive posts
    Last Post: 07-02-2007, 11:30 PM
  4. MK 3 Gti 16v Fault Code - ABS Problem
    By dravidham in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 16-01-2007, 08:10 PM
  5. Fault Code 058F - Help!
    By Nuggs in forum Chat - Completely Off Topic
    Last Post: 24-04-2006, 02:58 PM
