Thread: Strange Indicator behaviour
  1. Strange Indicator behaviour
    Aug 2008
    Our Golf mkV 1.9 TDi Se has started behaving very strangley in the indicator department. Sometimes its completely normal, sometimes you get nothing and it doesnt do the few quick flashes as you lift the stalk. Once this has happened next time you indicate it flashes the WRONG side indicators! This can be very dangerous and is at best rather worrying!
    Do you reckon its the switch, a relay or someting wrong with the "brain".
    I cant find any other related posts on this so maybe it isn't a common fault but it needs fixing so any ideas on the cheapest method wuld be gratefullt received.
    Jon
  2. Re: Strange Indicator behaviour
    York, UK
    I have never heard of this problem before. It sounds like a faulty control module/"brain". That said, a common problem with Mk V's fitted with cruise control is the cruise control system sometimes just trips out for no obvious reason. When this happens, you just need to turn the ignition off and on again and it's right as rain. This fault is apparently down to a faulty control stalk. Since it's the same control stalk that operates the indicators, I wonder if this might be causing your car's strange indicator behaviour.
    I'd recommend you let a VW dealer take a look. I know it costs a bit but hopefully they'll get this strange problem solved quickly.
    Stuart
    http://www.stuartdalby.co.uk/vwgolfmk5
  3. Re: Strange Indicator behaviour
    Aug 2008
    Thanks. Yes we do have cruise as well being an SE and the word from the daughters is that if you set cruise the indicators always seem to work.
    Looks like a faulty stalk then. I looked on ebay but they seem quite rare for Mk V's with cruise...there is one from an 08 GTi diesel that may be the same...
    I may well take your advice and let the dealer have a look.
    Jon
  4. Re: Strange Indicator behaviour
    Mar 2008
    our mk5 golf does the same, you can set the cruise control i.e on the motorway, indicator to move lanes and the thing trips out, but the worrying thing is the indicators work then dont work, kind dangerous, so trying to locate one, bet they not cheap!
    Power is nothing without Control!
  1. Car making strange noises when starting.
    By u03am5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2009, 02:31 AM
  2. Transporter van 57 plate strange noise
    By robbeyboys111 in forum The Commercial Range
    Last Post: 16-06-2009, 03:25 PM
  3. Strange noise from turbo
    By cat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2009, 10:50 PM
  4. Question Strange sound - similar to ABS activating
    By Audidua in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-04-2009, 11:40 AM
  5. VW T4 2.4 (94) Strange Gear Change Problem
    By holbornes in forum The Commercial Range
    Last Post: 21-07-2007, 11:04 AM
