Thread: Clutch Faulty - what bits need to be replaced?
  1. Clutch Faulty - what bits need to be replaced?
    ChillOut Guest
    2004/5 B5 Passat 130TDi.
    Any advice of the minimum components that should be replaced if I have suffered bad clutch judder for 10-15K miles?
    Don't know what the cause is yet, but VW agree its faulty and will be changed under warranty. It could be flywheel or contaminated plate by oil leak, or something else!
    But I am concerned that they may not replace connected components that may have been damaged by the problem.
    Any advice on what would be reasonable to insist upon?
    Nov 2006
    derbyshire
    With it being under warranty, stamp your feet! It could be contamination due to oil leak, or friction plate warped and same goes for the pressure plate. Fly wheel may be shot? Who knows? Get all the bits changed.
    Feb 2006
    have you had the recall.....having the clutch cover plate fitted on the gearbox...this was done to stop water dripping into bell housing casuing damage to clutch and flywheel..
    ChillOut Guest
    Quote Originally Posted by shooey88 View Post
    Yes I recall (npi) this was done quite some time ago. Either too late or I have another fault.
    ChillOut Guest
    Quote Originally Posted by gresty View Post
    Well, they say worn out (at 40K!) and because of the slipping, the flywheel is high spotted by overheating too. I don't buy it really, I think the fault was manufacturing and the overheating and wear came as a result, but as the lease company's paying I am not going to argue.
  1. Ur Quattro Bits
    By audiurme in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 03-03-2008, 11:46 PM
  2. New clutch judders - faulty clutch fitting or fly wheel?
    By srana in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-10-2007, 09:31 AM
  3. New Bits ...GOLF IV GT TDi
    By st0ned in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-03-2007, 07:36 PM
  4. Has Anyone Removed & Replaced a Door?
    By TDi_B5 in forum Passat - Archive Topics
    Last Post: 18-02-2007, 03:35 PM
  5. Replaced headlamp bulbs, but still low beam doesnt come on!
    By Bonus77 in forum Passat - Archive Topics
    Last Post: 09-11-2006, 02:47 PM
