Thread: my mk3 vr6 headache
  1. my mk3 vr6 headache
    Apr 2007
    can anyone help me? my vr6 starts but then cuts out straight away the batt had died so i have replaced it the central looking will lock the doors put the windows up but will not unlock you have to manualy open it?
    thanks carl
    Apr 2007
    Repulik Of Mancunia
    Could be the alternator, not charging the battery correctly.
    Get a meter out and test the voltage from the alternator to the + on battery.
    Should read around 12V +
    '99 Golf GT-TDI
    MUFC - One Love
    Good Rep Always Appreciated.
    Dec 2006
    Wiltshire
    Quote Originally Posted by betham1@hotmail View Post
    thanks carl
    Sounds like the immobiliser key isn't being picked up by the ECU.
    Does it run for about 2-3 seconds then just die? If so I suspect that the ECU and the Key aren't talking to each other. Have you tried your spare key?
    If you can, (with a window OPEN) try pressing the locking button on the key during the brief seconds the engine is running, sometimes this will resync them. If not probably off to VW or a VAGCOM equipped man.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  1. New Member With Big Headache
    By sharky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-05-2007, 08:48 AM
  2. 1999 bora starting headache
    By boxofmatches in forum Bora - 1998 - 2005
    Last Post: 04-01-2007, 11:19 PM
