Thread: Polo - passenger side window
  1. Polo - passenger side window
    Apr 2007
    London
    Hi evryone, I've got a 3dr polo 98 and the front passenger side electrical window doesn't work, the drivers side works fine. The switches have been checked. The window was working fine and then the car was parked up for a while and the window stopped working and since then worked once but never again! :S Anybody got any ideas? Any help is appreciated, cheers!
    Aug 2006
    Devon, UK
    Dodgy connection? Could be rusted? Your best bet will probably be to get the door panel off and have a look around. If you can use a multimeter check that power is being supplied to the motor when you press the switch. Does it make any noises when you try to use it (and from where), or is it completely dead?
    Passat Sport Estate 2001 1.9 TDI PD
    100k miles
    Apr 2007
    warrington
    if you undo the clamps that hold the glass (10mmbolt) prise the clamp apart you may be able to see if the motor is working sometimes the glass gets jamed at the top of the door if you need any advice give me a shout
    Feb 2006
    check the wiring inbetween the door and a pillar..just pull the rubber grommit back n u mite find the wiring broken. let us know what u find
    Feb 2007
    I have a similar problem with my drivers side electric window, everytime it goes down it is fine however when i try and bring it back up sometimes it will work and other times it gets about 10cms away from the top then stops and goes down a little bit and i have to hold my finger on the switch to get it to the top but it goes really slowly. If anyone knows what could be wrong it would be much appreciated.
    Apr 2007
    warrington
    the motor could be on its way out but before that take the panel off not sure what car you have may just need some slight ajustment and a spray of wd if it still drops down let me know and i ll talk you through the reset of the window (has the window been broken)
    Feb 2007
    Cheers bud. The window isn't broken no but you may be right with the motor being on it's way out. The drivers side is much slower than the passenger side. Any ideas of how much I'm looking at if it the motor??
  1. WATER in passenger side... Near top of footwell
    By Anzee in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-01-2011, 06:43 PM
  2. Sharan electric window, passenger side
    By paulnh in forum Touran - Sharan - Caravelle
    Last Post: 21-06-2007, 08:37 AM
  3. Window and Unlock Buttons Linked...Passenger Side (bora uk)
    By SpiderVann in forum Bora - 1998 - 2005
    Last Post: 29-05-2007, 01:40 PM
  4. Passenger side front window knackered?
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2007, 05:56 PM
  5. damp carpets-front passenger side
    By laujen in forum Passat - Archive Topics
    Last Post: 20-07-2006, 11:49 PM
