Thread: All Doors Wont Unlock
  1. Question All Doors Wont Unlock
    Apr 2007
    Hey guys, im brnad new to this forum thing and just wanted to see if anyone could help me... Alright so, so far, two things wrong with my '02 vw passat 1.8...
    i went to put some adhesive on my door panels being that the cloth was loose and was coming off... in doing so, i pulled off the drivers side panel loosening all the wires under neath and behind. when i pull all of them back, the switch on the door to open the trunk and gas release door doesnt work!!! now i have to manually open the gas door through my trunk!!!
    Second, recently have been letting my dad use my car to commute back and forth from work... Come to use my car, in trying to unlock my doors from my master key, press it twice, and all the doors dont unkock as they usually would. Pressing the button a hundred times, it still on opens the drivers side door...
    So please please please guys, if you have any solutions to these problems, let me know!!!!
    THANKS
  2. Do it again
    Mar 2007
    Cornwall
    If your locking and petrol lap release worked before you did your sticking job, I would suggest you've caused a bad connection on your switches in the door. So get back in there and make sure all the connections are pushed home 100% and that you hav'nt yanked any wires out. GOOD LUCK
    Apr 2007
    My '01 olds does the same thing. I think it's a preventive measure to keep you from locking your keys in your VW parts. Do you have a key for remote? Check your VW repair manual or your owners manual. There may be a programming sequence you can do to set the system.
    Goodluck!
  1. Golf Mk4 rear door won't unlock
    By CrossMouse in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2020, 12:34 PM
  2. How unlock all doors with one button press on the remote
    By vwpolo in forum VCDS - General Questions
    Last Post: 27-01-2020, 12:35 AM
  3. Window and Unlock Buttons Linked...Passenger Side (bora uk)
    By SpiderVann in forum Bora - 1998 - 2005
    Last Post: 29-05-2007, 01:40 PM
  4. passenger door will not unlock
    By photogr22 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-04-2007, 10:52 PM
  5. Unlock the boot and the windows open?!
    By The Stagg in forum Passat - Archive Topics
    Last Post: 06-01-2007, 11:55 PM
