Thread: Cambelt check up?
  1. Cambelt check up?
    Sep 2009
    Stourbridge
    Hello to everyone im a new member with a Golf GT TDI, my car has a had camblet at 110,000 miles (now on 117,000) according to the service book but i have no recipt to prove this work, is it much of a job to get to the cambelt to check the condition of it?
    Dave
  2. Re: Cambelt check up?
    Pembrokeshire
    22 Post(s)
    its not too much bother to remove the top cover, but the only way to examine a cambelt properly is to remove it and bend it back on itself to check the teeth, after which you wouldnt want to re fit it anyway. if you are in doubt whether it was changed, then i would be inclined to have it replaced, along with the water pump. that way youll know its been done and wont be landed with a big bill if it hasnt been changed.i often get asked to check a cambelt. its quite a simple answer; no. i will either fit a new one or nothing at all. then if it does go at a later date, i cant be held at all responsible.
  3. Re: Cambelt check up?
    Sep 2009
    Stourbridge
    Thanks for quick reply, That makes sense, I know its hard but any idea of what sort of price im looking at for a cambelt and pump change at a independent specialist?
  4. Re: Cambelt check up?
    Jul 2008
    High Peak, Derbyshire.
    Dave
    I have had 3 quotes:
    1) Main dealer - £345 (inc VAT) to include belt, tensioners and water pump.
    2) main dealer - £295 (inc VAT) above but no water pump.
    3) Indy - £295 (plus VAT) to inculde belt, tensioners and water pump. £340 all in if my maths is right.
    I am going with main dealer mainly because the indy is over 20 miles away and the dealer is just down the road.
  5. Re: Cambelt check up?
    Sep 2009
    Stourbridge
    Seems like it would be worth having it done at a main dealer at that sort of money, will ring them up today.
    Thanks for the help
  6. Re: Cambelt check up?
    Jul 2008
    Got mine done today. Bizarrely the bill came to £345 - 02. Don't know where the 2 p came from.
    That should be it for the next 4 to 5 years. I've said this before but if you see it as £80 + per annum it doesn't seem so bad!
  1. A6 1.8T Overfuelling
    By soulsearcher in forum VCDS - General Questions
    Last Post: 17-07-2009, 12:53 AM
  2. "How To" The FAQ & How To Thread
    By Ben in forum General
  3. Bora 2.0i Service Schedule Missing
    By zimbora in forum Bora - 1998 - 2005
    Last Post: 10-04-2008, 11:45 PM
  4. Service Checklist
    By Foxcub in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2008, 01:41 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
