Thread: Where is the Water drain hole
  1. Where is the Water drain hole
    May 2009
    FRANCE
    I have a build up of water just underneath the pollen filter Where is the water drain hole as it is bunged up no doubt?
  2. Re: Where is the Water drain hole
    May 2007
    knee deep in clunge
    14 Post(s)
    beneath the battery tray and also check the grommet surround for the clutch hydraulic pipe besides the servo
  3. Re: Where is the Water drain hole
    May 2009
    FRANCE
    Quote Originally Posted by a8 tech View Post
    So will I have to take the battery out or not?
    Tim
  4. Re: Where is the Water drain hole
    Aug 2007
    Newport, Wales
    7 Post(s)
    Yes.. and the best tool to un-bung grommet is one of your pinkies!
    It's a real pig to get the battery out.. you need a really long allen key (preferably with a rounded end) to undo the bolt & retaining bracket. The longest allen keys Halfords sell aren't quite long enough - I got my set from B&Q and even then, it's only just long enough!
    a8_tech - do Audi workshops have an especially long one just for the job? (allen keys, not pinkies) LOL!
    Regards
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  1. another nother nother water leak, helppppppppp!
    By ahsanx in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-12-2009, 01:55 PM
  2. a4 water drain point
    By SWARCUP in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-09-2009, 11:29 AM
  3. Gearbox oil level
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 13-08-2009, 01:11 AM
  4. Water in Front Passanger Footwell
    By triumphman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-05-2008, 03:54 PM
  5. Water leak and drain holes
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-03-2008, 03:16 PM
