Thread: 1999 Passat 1.8T high revs on start up
  1. Question 1999 Passat 1.8T high revs on start up
    Apr 2007
    Hi Guys
    I'm generally the proud owner of a Passat 1.8T 1999 but... every so often it will rev to about 2000 rpm on start up and after about 2 seconds settles down to normal. It generally does this on the first start of the day. On occaisions it will also not start until it has been wound on the starter for 30 seconds. It's covered 95K miles and has been regularly dealer serviced and is generally in VGC.
    Can anyone give me any clues? The main dealer doesn't seem to know!
    Whitejc
    Feb 2006
    no faults in the ecu? first obvious thing to check would be throttle body. can cause poor idling and poor starting or stalling.
  3. Thanks
    Apr 2007
    Hi Shooey88
    Many thanks for the quick reply. I will take a look at the weekend. If there's no prob with the throttle body I don't know how to check the ECU. I've heard there is software available to install on a lap top and do your own diagnostic with... do you know anything of this?
    Whitejc
    Oct 2005
    Lutterworth
    It's probably the coolant temperature sensor.
    Cheap and easy to replace.
    It's located at the back of the head.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  5. To Lex Luther
    Apr 2007
    Hi Lex Luther
    I replaced the coolant temp sensor as suggested... it seems to have done the trick, time will tell. After fitting, the engine started sweetly and settled immediately at tick over. Many thanks. J White
  1. low revs on cold start -golf mk3 1.8
    By noho in forum Golf MK3 - 1993 - 1999
    Last Post: 20-08-2009, 05:38 PM
  2. 99 plate 1.8 revs are high on automatic
    By Maz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-11-2008, 04:45 PM
  3. Passat TDI high revs on cold start
    By weaverus in forum Passat - Archive Topics
    Last Post: 28-02-2007, 03:37 PM
  4. Miss-firing at low revs - Golf 1.6 1999
    By joe1703 in forum Archive posts
    Last Post: 04-12-2006, 06:07 PM
  5. Corrado VR6 stalling at low and high revs
    By Minanmic in forum Archive posts
    Last Post: 16-02-2006, 11:36 PM
