Thread: mk4 golf 6 speed conversion
  1. mk4 golf 6 speed conversion
    Sep 2008
    Is this plausable? Cars currently a 2000 2.0 Gti 115BHP APK Engine and would like a 6th gear for motorway driving. I'm assuming it'll be a flywheel, box, driveshaft swap etc?
  2. Re: mk4 golf 6 speed conversion
    May 2007
    It is not really worth it. Just get a golf with 6 speed box if you want one. It is possible to do, but expencive.
  3. Re: mk4 golf 6 speed conversion
    133 Post(s)
    1991 Post(s)
    It is extremely involved and complex and even the ECU needs to be recoded to work with the box and I don’t think that ECU can be coded for 6 speed plus finding a 6 speed with suitable ratios may be tricky. I looked into this on my Octavia VRS (using a Leon Cupra box which uses the same engine and ECU) when I was fitting a new engine and the price difference of the clutch/DMF alone was enough to put me off, it was literally three times the price. The only petrol front wheel drive Golf 4 to use the 6 speed was the Anniversary 180.
  1. In-Car Speed Limiters Go On Trial In London
    Last Post: 12-06-2009, 05:46 PM
  2. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  3. Modifying a Golf MK4 - Peoples Views?
    By rickgti in forum Golf MK4 - 1999 - 2004
    Last Post: 31-03-2007, 03:28 PM
  4. New Golf Estate Set To Break Cover At Geneva Motor Show
    Last Post: 27-02-2007, 09:15 PM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
