Thread: VAG COM codes and how to repair
  1. VAG COM codes and how to repair
    Oct 2009
    belfast
    Im a novice to all this stuff and am looking some help I ran VAG on my 2002 2.5Tdi sport(manual) and got the following faults back.
    00777 Accelerator Position Sensor
    01265 EGR Valve
    01375 Engine Mount Control Solenoid
    When I start car and press the accelerator the ESP light illuminates and car goes into limp mode.Anyone help me please
  2. Re: VAG COM codes and how to repair
    Jun 2007
    attempt to clear the codes. then drive the car and see which ones return. go from there....
    I would say from the above list that and fault description that the throttle potentiometer is what is causing your ESP light. This does not necessarily mean that the potentiometer is at fault. If this fault code returns you need to check the readings from the various tracks (typically 2/3 track) on VAG. they should read about 1v to 4.5-5v. remember, one track reads inverse to the other.
    hope this helps.
    AvantTdi
