Thread: 1.6 fsi not starting intermittently
  1. 1.6 fsi not starting intermittently
    Oct 2009
    Ireland
    Hi lads
    My passat wont start every now and then. When I put the key in it makes a clunking sound, no lights on the dash. Remove key try again and it works fine. It's happening more frequently now, but each time it has eventually started. Someone told me I need to get key reprogrammed? anyone any ideas?
  2. Re: 1.6 fsi not starting intermittently
    131 Post(s)
    1976 Post(s)
    It sounds like the typical steering column electrics fault that is becoming a real problem on the 3C Passat. You need to have the car scanned for fault codes and in the immobiliser you may have “02823 - Requirements for Locking the Steering Column Lock not met 000 - - - Intermittent” which means a new switch, immobiliser unit and steering column electrics unit is required. I can’t do these yet and I don’t think any other non franchised VW garages and my local dealer charges just under £900 to do this job so I hope yours is still under warranty.
  1. VW Golf 1.6 FSI Engine noise
    By David Farmer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-05-2009, 11:10 AM
  2. Audi Cuts New A3 Engine Down To Size
    Last Post: 14-08-2007, 10:18 PM
  3. Audi Injects Even More FSI Efficiency Into 2007 Range
    Last Post: 04-12-2006, 08:06 PM
  4. A8 3.2 FSI NOW WITH ADDED QUATTRO SECURITY
    Last Post: 11-08-2005, 08:34 PM
  5. Audi launches efficiency drive with New A6 FSI models
    Last Post: 23-05-2005, 07:34 PM
