Thread: white smoke, burning smell
Results 1 to 10 of 17
  1. white smoke, burning smell
    Oct 2009
    essex
    hate to do this on my first post.
    bloke come down with his audi to sell to me, i took it for a test drive and it pulled and drove lovely, so i payed for it.
    in the morning i turned it on and loads of white smoke come out the exhaust and it stunk of burning, like oil burning if anything.
    first thoughts are bye bye turbo but the smoke wasn't blue, there no mayo round the filler cap so head gasket ok.
    i sure its the turbo but what can people recommend????
    thanks
  2. Re: white smoke, burning smell
    Oct 2009
    essex
    oh and no ECU light or funny noises and once warmed up smoke reduces alot
  3. Re: white smoke, burning smell
    133 Post(s)
    1991 Post(s)
    And the engine is a...
  4. Re: white smoke, burning smell
    Oct 2009
    essex
    1.8 20v turbo, 150bhp version i think, although the bloke did say he thinks turbo been changed and a remap from prev owner to 230bhp.
    straight threw exahaust with de cat
  5. Re: white smoke, burning smell
    133 Post(s)
    1991 Post(s)
    From what you describe it sounds like the turbo has failed. This is normally due to sludge in the sump and just fitting a new turbo is no use. I would be very wary about driving it and I suggest the sump is pulled ASAP to check for sludge. How are you going to get an MOT without a cat?
  6. Re: white smoke, burning smell
    Oct 2009
    essex
    it was already MOT'd. going to change it as its way to loud for my liking, depends what kind of bill im looking at to get this problem fixed!
    it smokes as soon as the exhaust gases are warm,ike after 30-40 seconds.
    deos that mean internals are buggerd aswell? what damage am i looking at?
    thanks for the help....
  7. Re: white smoke, burning smell
    Oct 2009
    essex
    what i mean also is where do i go from here, if the sump has sludge (im guessing you mean lumps of burnt black oil
  8. Re: white smoke, burning smell
    Oct 2009
    Greatstone,Kent
    Best bet would be to drop the oil,then remove the sump to give it a good clean out.Put it back and fill back up with some good quality fully synthetic oil 5W40 is what i use.Then,do a compression test to make sure the engine is still a gooden.If that shows up ok,look on ebay for a recon turbo as they sell on there for £100-£150 ish.If it is running at 230 Bhp it will at least have a K03s turbo,but possibly the K04 if its got the different manifold fitted.But so many people remap a standard 150 and qoute stupid figures that just arent true. When looking for a turbo on ebay,to determine if its a K03,it will have 12 fan blades,if its a K03s it will have 8 fan blades.Hope this helps
  9. Re: white smoke, burning smell
    Oct 2009
    essex
    thamks t sport, i descoverd the dip stick reading was high, upon draining the oil it eventually stopped at 7 and a half litrs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    now refilled to 4 and a half ish.
    still smokes but not as much by far!
  10. Re: white smoke, burning smell
    Oct 2009
    Greatstone,Kent
    7 and a half!Bloody hell. You will probably find the smoke will clear in time
  1. White smoke on cold starting
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-03-2013, 10:57 AM
  2. Please Help 99 1.4 16 v White smoke. Help?
    By pauliemk4 in forum Golf MK4 - 1999 - 2004
    Last Post: 20-08-2009, 09:52 PM
  3. Yet another white smoke on cold start - but maybe fixed?
    By richard_gomm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2009, 04:35 PM
  4. White Smoke, burning smell, low mpg...
    By friedgold in forum Archive posts
    Last Post: 30-12-2007, 10:33 PM
  5. White Smoke
    By Speedy in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2007, 11:44 PM
