Thread: Baude rate?
  1. Baude rate?
    May 2009
    Leeds
    I have been using the 409.1 freeware version of VAGCOM on my 98 Sharan for a few years now with no probs and have just bought a 2001 Polo 1.4 16v. The problem I have is that when I plug into the Polo it refuses to talk to the engine controller but other units it has no probs with i.e. ABS controller.
    So is it either:-
    A) need to change the Baud rate on the laptop to a different setting for each car
    or more worringly
    B)a problem with the Polo?
  2. Re: Baude rate?
    Ambler, PA, USA
    Try changing the baud rate. This is a problem that Ross-Tech faced in designing our interfaces. The inexpensive interfaces cannot adapt to different rates of control modules. So, you can have a play with the baud rate to see if you can get reliable comms. Then you will need to change it for your other car.
  3. Re: Baude rate?
    May 2009
    Leeds
    Hi Bruce, thanks for the help, will give it a go and try to remember to write down which settings for which car if I can!
  4. Re: Baude rate?
    Magdeburg, Germany
    There are not many Baud Rate settings between you may need to switch, however if you are using our genuine hardware (HEX, HEX+CAN, KEY/KII) you will not have that issue because the baud rate is automatically detected.
    There's a note about that on our website...
    http://www.ross-tech.com/vag-com/issues.html
    If when you try to connect to a control module, you get the error message "Can't Synch Baud Rate", go to the Options Screen and try setting the Start Baud to 9600. If 9600 doesn't work, also try 4800 and 1200. Turn the car's ignition OFF and back ON after each failed attempt to connect!
    Sebastian @ www.Ross-Tech.com
  1. Please Help P0441 fuel evaporation system flow rate faulty
    By audiyoudo in forum Golf MK5 - 2004 - 2009
    Last Post: 14-02-2010, 06:56 PM
  2. Rate my A4 1.8 tFSI -- AUSTRALIA
    By mohpr131 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-07-2009, 02:24 PM
  3. Going rate of interior valeting
    By RickT in forum General Detailing/Cleaning Questions
    Last Post: 04-09-2008, 07:03 PM
  4. going rate
    By mick1 in forum Bora - 1998 - 2005
    Last Post: 08-12-2007, 09:05 PM
