Thread: VW Golf TDi problem starting from warm!!! Help?
  1. VW Golf TDi problem starting from warm!!! Help?
    Apr 2009
    Hi guys, I will get straight to the point, I bought a VW Golf GT TDi about 3- 4 months ago, basically since I had it, it has trouble starting when it's warm, when staring it from cold, it's fine, I find this very strange. I had the heater plugs changed and the problem is still there, can anyone help me diagnose the problem/ cure?
    Thanks in advance.
    Ben.
  2. Re: VW Golf TDi problem starting from warm!!! Help?
    Southampton, UK.
    To disgnose, plug into the car with a laptop, cable and VAG-COM. A temperature related starting issue is likely to be the coolant temperature sender. Anyhow, a fault code read should throw that up if the sender is faulty.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  1. Golf Mk4 TDI Occasional Misfire
    By Graham Mason in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2008, 06:02 PM
  2. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  3. Golf III TDi, Starting Problem
    By Joe911 in forum Golf MK3 - 1993 - 1999
    Last Post: 08-10-2007, 08:30 PM
  4. ADVANCED NEW FOUR-CYLINDER PIEZO TDI ENGINE
    Last Post: 17-05-2006, 08:14 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
