Thread: Please diagnose my air con problem!
  1. Please diagnose my air con problem!
    Aug 2009
    Northampton United Kingdom
    Hello all,
    I have the winter pack on my golf and the air con does not start now. When working it used to make a "clunk" then start, now there is nothing. Heating and air still work. I read on the site that fans and condensers can die- which does this sound like?
    Is there anything I can test to give more info to you, or to narrow down the cause?
    Many thanks
    Car- Skoda Octavia 2.0 VRS Estate 2007
  2. Re: Please diagnose my air con problem!
    Sep 2009
    England
    First step is to check if there's gas in the system.
  3. Re: Please diagnose my air con problem!
    Aug 2009
    Waiting on an answer as to if it's been gassed will let you know.
    I meant compressor above, not condenser, apologies.
  4. Re: Please diagnose my air con problem!
    Oct 2007
    Ckeck the fuses on the fuse box on top of the battery
  5. Re: Please diagnose my air con problem!
    May 2008
    huddersfield
    Take off the wheelarch liner on the drivers side so you can see the compressor pulley.
    Remove the drive belt.
    put a spanner on the pulley centre bolt and see if the compressor will turn.
    Mine was seized solid.
    The compressor pulley has a 'weak point' so that if it seizes the pulley will rotate rather than snapping the drive belt.
  1. Sharan Air Con Problem
    By phall in forum Touran - Sharan - Caravelle
    Last Post: 26-01-2011, 02:12 PM
  2. Golf Air Con Not Cooling
    By colinmchardy in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2009, 12:51 AM
  3. Air con compressor problem
    By rhysdavies in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-05-2008, 11:48 AM
  4. A4 Air con problem
    By fifehibby in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2008, 08:03 PM
  5. Golf TDI Air Con Problem
    By amw5 in forum Chat - Completely Off Topic
    Last Post: 31-12-2006, 05:22 PM
