Thread: AAZ 1.9 mk3 golf glow plug change
  1. AAZ 1.9 mk3 golf glow plug change
    Oct 2009
    Terrace B.C Canada
    Im looking into whether or not i need to change my glow plugs. What are the signs i should look for before i change them? Is there anything in particular that my engine will do while the plugs are wearing out? It is having a bit of a hard time starting in the morinings if thats a signs?
    Im also wondering if i need to take my fuel pump off to be able to get the glow plugs out? it seems like the pump is to close for the plugs to be able to pull out.
    any ideas?
    Thanks,
    Will.
  2. Re: AAZ 1.9 mk3 golf glow plug change
    Dec 2008
    Bad starting is definately a sign of plugs wearing out (although the weather's getting a bit colder too, so that won't help). as they're cheap, I'd swap them out, it should make your starting a lot better.
    Having never done this job, afraid I can't give pointers on how easy or hard it is.
  3. Re: AAZ 1.9 mk3 golf glow plug change
    Oct 2009
    Terrace B.C Canada
    okay, thanks Im just gunna look into it more to see how to change them. In my Haynes manual it shows the plugs being removed but it is when the head is off the engine so it does not help at all..
  4. Re: AAZ 1.9 mk3 golf glow plug change
    You do not have to remove the fuel pump to replace the glow plugs,but you can remove the injector pipes,which will make it easier
  5. Arrow Re: AAZ 1.9 mk3 golf glow plug change
    Jul 2008
    Poor starting, poor acceleration - sluggish response.
    Black smoke from exhaust on accelertion or general driving.
    Remove the injector pipes, this job is really easy !
  6. Re: AAZ 1.9 mk3 golf glow plug change
    Oct 2009
    Westbury,Wiltshire
    Quote Originally Posted by TheShow View Post
    any ideas?
    Thanks,
    Will.
    Will How did you get on, have you changed glow plugs
  7. Re: AAZ 1.9 mk3 golf glow plug change
    Apr 2007
    Coventry
    hi one lil tip if you have one of those extendable magnet gadgets have it handy when changing the plugs... those lil nuts can be a tad tricky!
  1. mk3 golf 1.9td aaz timing belt change
    By leroybrown1984 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-09-2009, 02:57 AM
  2. Question Steering Pump Removal from MK3 Golf TD engine code 'aaz'
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-04-2009, 11:37 AM
  3. Glow plug light golf SDI 03
    By Gary C in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 04:48 PM
  4. Golf tdi 1.9 mk3 servicing/cambelt
    By veedub76 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-01-2008, 09:47 PM
  5. Golf Mk3 Cambelt Change
    By mickgr in forum Golf MK3 - 1993 - 1999
    Last Post: 07-09-2007, 06:20 PM
