Thread: A4 Cabriolet S Line Startup Checks Help !
  1. A4 Cabriolet S Line Startup Checks Help !
    Oct 2009
    LDN
    Hi guys,
    Hope you're all well, and that someone can point me in the right direction on this as I'm now at a total loss for a solution after trying to resolve the issue !
    I bought an A4 Cabriolet S Line and absolutely love it, Audi's are definitely the best cars out there. When I first got it (about 2 weeks ago) the driver display would run through the diagnostic checks whenever I started the car up. It would go through a sequence of checks, such as brakes, coolant, washer fluid et cetera and display an icon for each on the display as it performed the check. I liked this cool little feature !
    Well, after going through the on board computer menu and looking through the different settings etc it's stopped working. When I turn the car on now, it jsut comes up with 'OK' on the display after a few seconds.
    Is there some way I have disabled this visual check accidently through the menu ? I'm not sure if that's even possible, but it's the only link I can make between it working originally and now it not doing this check.
    It still works when I press the 'check' button, but it was a nice feature when it performed this automatically when firing the car up.
    Any help anyone can offer would be much appreciated !
    Thanks,
    Andy.
  2. Re: A4 Cabriolet S Line Startup Checks Help !
    Norwich
    Mmm never had that run through the cycles on start up on both of my B7s, but just the OK flashing up.
  3. Re: A4 Cabriolet S Line Startup Checks Help !
    Oct 2009
    sunny scotland
    strange, never really seen this fault before, with ignition on it should just display ok if everything is ok then go out. but have never seen it do a self check on everything itself without preesing the check button next the service light (spanner) and mileage reset
    By Redcap in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-10-2009, 09:18 PM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. World Debut For The All New Audi A3 Cabriolet
  4. Latest Audi A4 Specification Now Sounds Even Better
    Last Post: 06-07-2006, 09:25 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
