Thread: Engine diagnosis light
  1. Question Engine diagnosis light
    Oct 2009
    Aylesbury
    Hi, The engine diagnosis light has suddenly come on, permanently, on my Seat Leon, 1.9 diesel, 04 reg. Everything else seems as normal on the car, it drives the same as ever, no smells, etc. It was serviced, including fuel filter, 1,850 miles ago with no problems.
    All fluids and lubricants are as they should be and there doesn't appear to be any odd free wires etc in the engone area. I won't have access to a computer diagnosis for at least two weeks.
    Should I be worried, (as in new ECU slit-my-wrists job), or is it liely to be something trivial pertaining to this model of car?
    Any helpful suggestions would be greatly appreciated.
  2. Re: Engine diagnosis light
    Southern County Softy
    20 Post(s)
    Without a code read you'll never know !!
    A4 2.5 tdi QS (mapped)
  3. Re: Engine diagnosis light
    Oct 2009
    Aylesbury
    Thanks, looks like I will have to wait until I can get the computer read out.
    Peter
  4. Re: Engine diagnosis light
    Aug 2009
    Cardiff
    You could have a problem, like me, with the ABS/traction control module. If it is it can cost over £1000. Seems to be a common problem with cars in the VW Audi group, although they wont admit to it. If it is challenge Seat and contact Watchdog because Seat will not care.
    All the best to you
  5. Re: Engine diagnosis light
    Oct 2009
    Aylesbury
    I sincerely hope that my computer diagnosis next week doesn't reveal that I have to spend that much to fix the problem. If it is as bad as suggested I will indeed have a go at talking to Seat.
    Thanks.
  6. Smile Re: Engine diagnosis light
    SLeonCupra218BH Guest
    I wouldn't panic just yet and I certainly wouldn't listen to speculation about what the issue is or how much it MIGHT cost to repair. As usual, lots of ppl with no experience commenting on stuff they don't understand!
    You have a series of sensors on the car that report on various faults however they are not always accurate!
    Mass airflow sensor, fuel regulation, air fuel mix ratio everything, traction control is NOT included under this reporting system and has it's own independent reporting system so the chap that told you that was his problem was very clearly visible from a long way away from the salesman!
    Mine stays on permanently now reporting that a turbo hose is off (cant see it!) and that my temp sensor is at fault. I have replaced it three times along with the mass air flow sensor which needs changing every 100,000k anyway.
    Let us know what you find!
  1. HID Aftermarket kits - Not Legal....
    By RickT in forum Chat - Anything with wheels
    Last Post: 13-05-2011, 12:44 PM
  2. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  3. A6 2.5 TDI SE ENgine Management light
    By Red_Ade in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2008, 11:23 PM
  4. Engine managment light
    By cwilcock in forum Audi A3 - Archive Topics
    Last Post: 16-08-2007, 09:27 AM
  5. Engine Warning Light 2001 Passat
    By derekdublin in forum Passat - Archive Topics
    Last Post: 09-02-2007, 08:10 PM
