Thread: 1sr gear
  1. 1st gear
    Body in Cardiff...spirit in Ireland
    Hello,
    I have a 53 A6 1.9tdi manual. About 50% of the time its very difficult to engage 1st gear from neutral- sometimes theres a noise like 2 objects bumping off each other instead of engaging-coming off the clutch pedal and back on a few times sometimes solves it but sometimes you really have to force it in. I've checked all the gearbox mounts and they are good and there is no clutch slip. Any ideas? Can a clutch be worn out but not slip? Or is the clutch not disengaging correctly?
    Thanks,
    Dave.
    I have no idea what the problem is but try this.
    Instead of forcing it into first stick it into 2nd and then into first, it should go in with no probs.
    May 2007
    Quote Originally Posted by davegilsenan View Post
    Hello,
    Thanks,
    Dave.
    Sounds like clutch drag. You are not preventing the engine from loading the box and spinning the gears. Metallic noise would be gears crunching as you force it in.
    Does the clutch engage right at the bottom ? or are you not pushing it all the way down.
    It may need adjustment
    If you find your self in the fault mode just turn the engine off, if it then goes in no bother you have a clutch drag problem. Regards Peter
  1. DSG Gear Box
    By MikeXR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-06-2007, 07:46 AM
  2. Gear jumps out and non smooth gear changes
    By RIZWAN180 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-06-2007, 09:45 AM
  3. gear nob
    By doit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 07:05 PM
  4. Gear box oil
    By Jay in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-02-2007, 10:25 AM
  5. V5 gear box
    By mastermind in forum Chat - Completely Off Topic
    Last Post: 10-04-2006, 03:28 PM
