Thread: Water Pump
  1. Water Pump
    Sep 2007
    which side is it located in the engine bay?
    car's an 05 1.9 TDi
    got a squeak and I'm losing coolant
    is it a DIY job?
    if not a DIY job how much could I expect to pay in a non main dealer garage?
  2. Re: Water Pump
    Sep 2007
    log book says car has the following engine spec AWX 455763
  3. Re: Water Pump
    Oct 2009
    Essex
    Water pump is driven by the timing belt, if it is the pump that is at fault then you may as well have a new timing kit fitted! about £250 to £300!
    There's a fine line between genius and insanity!
  4. Re: Water Pump
    Oct 2009
    Essex
    P.S one other thing if it is the pump making that noise DONT RUN THE ENGINE OR DRIVE THE CAR ANYMORE!
  5. Re: Water Pump
    Sep 2007
    turns out it's the radiator that's split on the left hand side not the pump failing
    changing the cambelt, pump and rad whilst the fronts off
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Water pump moral - AAZ engine
    By the_old_diver in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2009, 11:01 PM
  4. ADR engine - Power steering / water pump belt
    By ANDY-C in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-04-2009, 01:11 PM
  5. "How To" The FAQ & How To Thread
    By Ben in forum General
