Thread: Timing Belt Marks
  1. Timing Belt Marks
    Oct 2009
    Kinross-shire, Scotland
    I've got an 80 1.9 TDI, 1994 and need to know how to line up the timing belt? Also, is this an interference engine? Ta xxx
  2. Re: Timing Belt Marks
    Dec 2007
    8 Post(s)
    Quote Originally Posted by K-Girl View Post
    There is a timing mark on flywheel which lines up with a straight edge at inspection hole. The inspection hole is roughly under fuel filter area on top of bell housing
    The other thing needs lining up is the camshaft with a proper flat bar in end slot
    windscreen side
    The fuel pump sprocket needs to be locked in position with a suitable sized
    bar/bolt
    Haynes manual for Audi 100 Gives good info on this procedure.
    Damage is caused if belt breaks
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  3. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  4. 1994 golf 1.8L timing marks
    By blake carstense in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 05-05-2007, 09:00 AM
  5. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
