Thread: Cam Belt Tensioner Help!
  1. Cam Belt Tensioner Help!
    Jun 2009
    ipswich
    Hi all. Anyone know if you can get the cam belt tensioner with the 8mm hole still? It is for the 2e engine. I brought a replacement tensioner but it came with a 10mm hole and a new 10mm bolt. Is the only option to re-tap the engine 2 10mm?
  2. Re: Cam Belt Tensioner Help!
    I would say you have got the wrong tensioner,there should be no problem getting the right one.
  3. Re: Cam Belt Tensioner Help!
    Jun 2009
    ipswich
    well thats what I thought but phoned a VW dealer and he said you cam only get the tensioner with a 10mm bolt hole. There must be someone selling the 8mm hole tensioner?
  4. Re: Cam Belt Tensioner Help!
    Jun 2009
    ipswich
    cam anyone help please?
  5. Re: Cam Belt Tensioner Help!
    http://www.vagcat.com/epc/cat/vw/PA/...22/49/1289471/You will find what you need here you need to find your engine number as there is different studs
  6. Re: Cam Belt Tensioner Help!
    Jun 2009
    ipswich
    Thanks Kenney.
  7. Re: Cam Belt Tensioner Help!
    Jun 2009
    ipswich
    Just had a look at that site kenney. I cant find a tensioner with a 8mm bolt hole on there. Only 10mm. Why is this I wonder? I have a 1993 2E engine. What am I to do?
  1. Cam Belt damaged
    By awmw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-12-2010, 08:54 PM
  2. Guide S4/A4 V6 Cambelt
    By spellmaster in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-10-2009, 05:23 PM
  3. Cam Belt Tensioner
    By steve1976 in forum Golf MK3 - 1993 - 1999
    Last Post: 31-08-2009, 04:40 PM
  4. Noisy serpentine belt tensioner - PD 150
    By nath_mkiv_150pd in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2008, 10:41 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
