Thread: T4 Diesel mechanic?!
  1. Question T4 Diesel mechanic?!
    Oct 2009
    Arundel UK
    Why can't I find a mechanic who can tell me what's wrong with my T4? I have a tappetty engine which is getting more clattery and is now losing power at 70mph+. I suspect the tappets AND perhaps a timing belt problem, but I'm no mechanic and don't know what a 2.5TDi is supposed to sound like!
    Does anyone know of a Veedoubleyouphile in West Sussex? Are you such a person? 'Normal' mechanics can't seem to be able to help, short of stripping the head and seeing what happens.
    I've changed the oil and filter to no avail
    PS, I'm not so much looking for ideas on what the problem is, but rather a garage in my area that you would recommend ringing. before valve meets piston...
  2. Re: T4 Diesel mechanic?!
    Pembrokeshire
    22 Post(s)
    the vacuum pump could be responsible for thr noise. ive known these to sound close to death. locate the brake servo and follow the plastic pipe back to the engine, where it plugs into the vac pump. remove the pipe and squirt some oil (wd40 etc) into the pump. if this cures the noise, jobs a goodun. if not,. the power loss could be unrelated, so a fault code read would be a good starting point for that.
  3. Re: T4 Diesel mechanic?!
    Oct 2009
    Arundel UK
    Thanks zollaf. That sounds like a quick and easy elimination exercise. Funnily enough, a mechanic I went to see today mentioned the same thing. However, he seems to think that it is a dodgy tappet, characterised by the intermittentcy of the tapping noise. I was surprised that a tappet could get this loud. He suggested I change the oil again, but add some Molyslip to try and loosen it up. His other advice was to live with it. It's too loud for that, so maybe I'll do my next cambelt change early and have the tappets replaced then. If that's the problem. Doesn't explain the 70mph+ misfire though...
    Anyhow - at least I've found a VW mechanic who has aleast half a clue. I found him in Itchenor near Chichester by chance.
  4. Re: T4 Diesel mechanic?!
    Pembrokeshire
    22 Post(s)
    the one i did sounded really loud, just like the engine was about to fall apart, but was ok a few seconds later. try the oil idea, and also try pumping the brakes when it does it.
  5. Re: T4 Diesel mechanic?!
    Dec 2008
    East Preston, West Sussex
    Jason,
    Did you try John Mitchell at JMR in Littlehampton by any chance? Nearer to you than Itchenor...
    John
    2005 A4 B6 Avant 1.9 TDI 130 Sport (6)
  1. Biodiesel - a summary
    By Huweth in forum Chat - Completely Off Topic
    Last Post: 06-01-2009, 06:25 PM
  2. t4 2.4 diesel advice please
    By red437 in forum The Commercial Range
    Last Post: 10-12-2007, 11:12 PM
  3. 2.4 diesel T4 Caravelle Panel Van, what to look for?
    By Mattygreg05 in forum The Commercial Range
    Last Post: 31-08-2007, 05:23 PM
  4. T4 alternative Diesel engines
    By markAsh in forum Chat - Anything with wheels
    Last Post: 05-07-2007, 06:56 PM
  5. The Audi Diesel Engines - Pure Power
    Last Post: 10-01-2007, 09:34 PM
