Thread: A3 2004 TDI Sport DSG S line
  1. A3 2004 TDI Sport DSG S line
    Oct 2009
    Bristol
    Hi Guys,
    Need some advice if possible.
    I have just bought an A3 S line 2.0 TDI from a private seller.
    Everything is great with the car barring 2 small issues:-
    1) I'm 99% sure that it has rear parking sensors but they just don't seem to do anything??
    Am I missing something in terms of an on/off switch?
    Could it be a fuse issue? If so is this easy to fix myself?
    Or is this something I have to get get checked out by Audi and swallow the cost!
    2) The car only came with one key fob and the lock and unlock only works 30% of the time.
    I think this is likely to be a key fob issue as it does work on occasions.
    What is the best/cheapest way to get a new key fob that works?
    I'm also thinking of remapping, will it make a big difference on my model?
    Cheers,
    Simon
  2. Re: A3 2004 TDI Sport DSG S line
    May 2009
    rhodesia, nottinghamshire
    Hi Simon,
    You can check your parking sensors with vag-com, that will tell you where your prob is with them. I take it you do have them? you should have what looks like small rings evenly spaced on your rear bumper.
    Find a local auto sparky that advertises key programming and he should be able to sort both your probs..
    A remap on your model gains 30bhp/75nm torque, which transform the way it drives..making it far better at low speed when you need to pull away and it is a bit sluggish..
    Just give us a shout if you need any more info mate....
  3. Re: A3 2004 TDI Sport DSG S line
    Oct 2009
    Bristol
    Thanks for the reply. Yep the small rings were what made me realise I had parking sensors but they haven't worked since getting the car.
    Will contact a local auto sparky to get those problems fixed.
    How much will it cost to remap my car?
    Cheers for all your help,
    Si
  1. Golf GT Sport 170 TDI DSG vs GTI
    By R P Leon in forum Golf MK5 - 2004 - 2009
    Last Post: 16-02-2008, 09:50 AM
  2. World Debut For The All New Audi A3 Cabriolet
  3. NEW TOUAREG SE AND SE SPORT MODELS OFFER MORE FOR LESS
    Last Post: 12-04-2005, 09:50 PM
  4. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
