Thread: A4 Air Bag & Cruise Control faults
  1. A4 Air Bag & Cruise Control faults
    Glasgow
    Hi, I have the following faults on my A4 1.9tdi 05 plate at 60,00 miles on the clock
    Two faults that i had for Audi to check out were
    1) Air bag warning light permanently on & Red - Audi Findings "require wiring repair to drivers side airbag igniter. Parts £17.00, Labour £140 ( 2hrs)
    Question:- does this seem as major a job as they make out?
    2) Cruise control not working - Audi findings: Require clutch pedal switch - parts £10.87, Labour £70 ( 1 hr ).
    Question: i have had a look and can see the switch i think that requires changing ( above clutch pedal) - is there anything majorly technical in changing this ?
  2. Re: A4 Air Bag & Cruise Control faults
    Dec 2007
    Quote Originally Posted by abolt View Post
    clutch switch is a 5 min job do it your self just make sure u do it right the airbag reapir is usaly the wireing under the seat iv had it on a few 4.s easy to do get parts from audi and do them ur self 90 mins tops for both
  3. Re: A4 Air Bag & Cruise Control faults
    Glasgow
    Hi Bez,
    appreciate your help very much.
  1. Had cruise control fitted today.
    By paulr130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-02-2010, 09:42 PM
  2. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
  3. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2007, 07:33 PM
  4. Fast forward to spring with new A4 Cabriolet S line range
    Last Post: 02-02-2005, 09:26 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
