Thread: A4 CD Changer wiring
  1. #1
    Dec 2006
    Wiltshire
    They will work (essentially the same unit) , but I'm not aware of any adapter that will allow you to simply plug it in.
    If you get really stuck and are OK at dismantling things I may be able to supply the correct lead that comes out of the unit for you to swap over.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    Apr 2007
    Hi Froggy,
    Thanks for the reply. I'm an electronics engineer so if you are sure they are compatible software wise then I'm up for connecting the two together. If you can supply the female round din style connector I would be most grateful.
    cheers
    Cliff
  1. Cd Changer Wiring Help
    By Dips in forum Audi A3 - Archive Topics
    Last Post: 19-04-2007, 02:46 PM
  2. wiring an amp in a mk4 TDI
    By bigwint in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2007, 03:36 PM
  3. Disk changer wiring loom.
    By floobydust in forum A2
    Last Post: 26-03-2007, 03:00 PM
  4. Wiring?
    By bromine in forum Passat - Archive Topics
    Last Post: 10-02-2007, 07:33 PM
  5. wiring up an amp in a a3
    By jkruse123 in forum Audi A3 - Archive Topics
    Last Post: 08-12-2006, 03:46 PM
