Thread: Brake Discs & Pads Sizes ?????
  1. Brake Discs & Pads Sizes ?????
    Aug 2009
    N.Ireland
    I'm going to change all discs and pads as the pads are done and the discs have a 5mm raised lip, which shows that there is a good bit of wear going by the thickness difference.
    I thought that the pads were meant to wear right to the edge of the disc?
    Is this correct or were the wrong pads or discs possibly used before.
    There are two different sizes of disc.
    Also there appears to be different types of caliper, Bendix & Lucas etc. How do you determine which is which?
  2. Re: Brake Discs & Pads Sizes ?????
    Norfolk
    Disc pads never go right to the edge of a disc so you always get an unworn lip. Correct disc and type of caliper can be obtained from VW via chassis number. Most motor factors can tell you using chassis number or even reg number.
  1. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  2. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  3. can i have some bleeding help please?
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-01-2008, 05:42 PM
  4. 03 Sharan brake psds
    By mistuart in forum Touran - Sharan - Caravelle
    Last Post: 17-11-2007, 10:41 PM
