Thread: Memory Ice
  1. Memory Ice
    Oct 2009
    Blackpool, uk
    ok new problem the head unit works fine however, it only plays when the key is in the ignition which is fine, if i take the key out then put it back in say 2 mins after the memory on the head unit is fine, if i put the key in say an hour later the memory has been wipe
  2. Re: Memory Ice
    Jul 2009
    have you tried swapping the red and yellow cables on the HU wiring harness?
    I like Golfs. Nothing beats the feeling you get seeing the chav that just overtook you in his french car on the hard shoulder.
  3. Re: Memory Ice
    Sep 2009
    South Wales
    the ignition and battery cables are reversed on the mk3 loom, a bit of splicing will fix the problem, Had to do it myself, sorted now though!
  4. Re: Memory Ice
    Oct 2009
    Blackpool, uk
    how do i do this ie which colour where?
  5. Re: Memory Ice
    Sep 2009
    South Wales
    i think ive got a pinout somewhere, i'will try to link it
  6. Re: Memory Ice
    Sep 2009
    South Wales
    these may help
  7. Re: Memory Ice
    Oct 2009
    Blackpool, uk
    all done thanks
  1. Problem with Advanced Key & One-Touch Memory
    By NeilA8 in forum A8 - S8 - V8
    Last Post: 29-11-2013, 09:51 AM
  2. How to change the key blade?
    By mrmonk21 in forum Golf MK4 - 1999 - 2004
    Last Post: 26-03-2008, 01:15 PM
  3. TT 2.0tfsi USB problems
    By AMTTT in forum TT - 8N Forum - 1998 - 2006
    Last Post: 01-10-2007, 10:10 PM
  4. Memory Issue On Headunit
    By kasper1287 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2007, 10:24 PM
  5. fixing Golf MK3 stereo memory...
    By dez in forum Golf MK3 - 1993 - 1999
    Last Post: 09-08-2007, 01:25 PM
