Hi all
I've had some problems with my wifes car but have managed to solve them all without cost thanks to this forum...great work guys!
I have some small probs that I can't resolve!
Some times when I unlock the car in the morning the hazards flash to show disarmed and unlocked,sometimes they continue to flash including lower front fogs.I'm guessing that's the alarm going off but no sound,the car starts and drives but they carry on for a couple of minutes then go off?????bizarre eh?
How can I test the alarm should there be an audible chirp when arming and disarming,how can I set it off? I have a button on the drivers side mid pillar that doesn't seem to do anything? says in the book how to set it's interior sensors but doesn't seem to make any difference.
Slight squeek at the sterring wheel or upper column (I Think) steering fluid is slightly lower that the minimum and I will get it topped up,could this be the problem? should I remove the column cowling and grease it all up.What do you think about winns stop leak for power steering?
The Concert stereo seems a little week with bass (Non Bose) do I have a sub in the rear somewhere or can I add one easy (Non Chav style, discreet) I compare it to the Passat we had and it's not a patch!
Thanks for any help!
