Thread: Conerting B6 rear light cluster to B7
  1. Conerting B6 rear light cluster to B7
    London
    I have purchased at set of B7 rear light clusters. There is a different connector on the B7's. I know there is an adaptor to fit the B7 to the B6 connector but I don't want to pay for a simple pin-out converter (with a resistor) for what is probably a 5 minute job with a soldering iron!
    Does anyone have any techie info?
    TIA
  2. Re: Conerting B6 rear light cluster to B7
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Sure you would see better response on b6 or b7 forum
    look out for ....crasher...this guy knows his stuff
    good luck
    stuart
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  3. A4 cab B7 rear light clusters on B6
    By linners in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 16-06-2009, 12:15 PM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
