Thread: Resetting the "Check Oil" warning?
Results 1 to 10 of 17
  1. Resetting the "Check Oil" warning?
    Mar 2009
    Yesterday, my Passat gave me the "Check Oil" warning... it was a little low, so I topped it up to the Max level.
    However, the Oil light stays on permanently now, and each time I start the car, I get the "Check Oil" warning...
    How can I reset this?
    Andrew
  2. Re: Resetting the "Check Oil" warning?
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by abucksdiver View Post
    Andrew
    I seem to remember reading on here, it'll be cancelled only if the bonnet open switch has been activated, and if it's not the oil light will stay on. And that the bonnet switches have a habit of not working.
    Number 11 in the picture
    Nothing to see here, move along..
    2 0 0
  3. Re: Resetting the "Check Oil" warning?
    Apr 2009
    You are 100% right, Bring the oil to the correct level and close the bonnet, would never have worked it out, many thanks hijamie
  4. Re: Resetting the "Check Oil" warning?
    Hi there,
    I'm suffereing with the same problem of the oil warning light not going off.
    to clarify do you mean that after the oil level has been refilled that you press that bonnet open switch to get rid of the warning?
    Sorry if my question sounds stupid.
    thanks
    C.
  5. Re: Resetting the "Check Oil" warning?
    Mar 2009
    Quote Originally Posted by conor2949 View Post
    Hi there,
    thanks
    C.
    The way I cleared mine in the end was to remove both terminals from the battery and to hold them together for about 30 seconds... this reset the Oil Level warning.
    (Note that your radio might go funny for a while... it took mine about 15 minutes with the ignition on before the radio "re-registered" with the ECU!)
    Hope this helps
    andrew
  6. Re: Resetting the "Check Oil" warning?
    Apr 2009
    In my case I set the oil to correct level and with the keys removed closed the bonnet. Then inserted the keys and started up the engine, light and warning went out and have stayed thet way. good luck, hijamie
  7. Re: Resetting the "Check Oil" warning?
    Norfolk
    If the bonnet switch is faulty, the light won't go out. The ecu needs to know the bonnet switch was opened and closed. Faulty bonnet switch often leads to alarm faults as well.
  8. Re: Resetting the "Check Oil" warning?
    Jul 2008
    almost def bonnet micro switch i had same problem bought new switch about £20 turned out to be broken wire by switch if switch is working properly you can get light out just by opening and closing bonnet!!!!!!![obviously temporary measure]
  9. Re: Resetting the "Check Oil" warning?
    1836 Post(s)
    Snake oil...
  10. Re: Resetting the "Check Oil" warning?
    Is it possible to reset the warning light using vagcom?
    I've got a 02 TDI 130 with AVF engine.
    Where would the bonnet switch be on this model? do I need to remove covers or something?
    thanks
    Conor
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. ABS warning still on
    By KeithS in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-11-2010, 10:36 AM
  3. 1.8T oil pressure on motorways
    By pippip in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2009, 01:03 PM
  4. Resetting disc warning light?
    By Spibes in forum Passat - Archive Topics
    Last Post: 17-09-2007, 10:11 AM
  5. Resetting brake disc warning light?
    By Spibes in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 08:49 PM
