Thread: Diagnosis codes, 05 B7 2.0TFSIQ
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
  1. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #21
    Oct 2009
    Cleveland, OH
    Don't get discouraged, it may be unrelated codes! Give it a scan and get back to us!
    :: www.ECStuning.com :: IS NOW OPEN TILL MIDNIGHT EST FOR PHONE ORDERS!!
    Phone: 1.800.924.5172 - 8:30 am to 12:00 am | Email: Pete@ecstuning.com | Questions? PM us for a quick response!
  2. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #22
    Aug 2009
    Norway
    Sorry for the slow response. I appreciate the interest!
    The dealer wants my car for a week or so and have the Audi tech drive the car as his "private" car to and from work and other daily stuff, while logging data as he goes, and then involve the official norwegian VAG importer and VAG in Germany. I'm sure they would be able to solve the problem together, and in a week, but it sounds like an expensive solution to me. They weren't willing to do another "off record" readout either, to see if the fault codes had changed, so I took the car to a friend with Autoboss V30, he's read out codes before, but for some reason it didn't work this time. I was tired of asking around and ordered VAG-COM instead, that's why it's taken time. I need to get it solved to get my beauty sleep again!
    Sitting in the car as we speak. I'm (so far) actually very impressed with VAG-COM, especially compared to low cost solutions for BMW (Carsoft).
    There's five faults this time, it's been four all the time before (at least as far as I know).
    Here they are:
    5 Faults Found:
    008583 - Bank 1; System too Lean at Idle
    P2187 - 004 - No Signal/Communication - MIL ON
    Freeze Frame:
    Fault Status: 11100100
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 171621 km
    Time Indication: 0
    Freeze Frame:
    RPM: 781 /min
    Load: 22.0 %
    Speed: 0.0 km/h
    Temperature: 76.0°C
    Temperature: 7.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.224 V
    008825 - Leak in Air Intake System
    P2279 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 171622 km
    Time Indication: 0
    Freeze Frame:
    RPM: 764 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 79.0°C
    Temperature: 9.0°C
    Voltage: 14.224 V
    012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
    P310B - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 171626 km
    Time Indication: 0
    Freeze Frame:
    RPM: 5424 /min
    Load: 100.0 %
    Speed: 116.0 km/h
    Temperature: 81.0°C
    Temperature: 12.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.097 V
    001287 - Idle Control System RPM: Higher than Expected.
    P0507 - 001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 171641 km
    Time Indication: 0
    Freeze Frame:
    RPM: 877 /min
    Load: 14.1 %
    Speed: 0.0 km/h
    Temperature: 82.0°C
    Temperature: 29.0°C
    Absolute Pres.: 980.0 mbar
    Voltage: 13.970 V
    001089 - EVAP Emission Control Sys: Incorrect Flow
    P0441 - 002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 2
    Mileage: 171680 km
    Time Indication: 0
    Freeze Frame:
    RPM: 775 /min
    Load: 22.0 %
    Speed: 0.0 km/h
    Temperature: 79.0°C
    Temperature: 8.0°C
    Voltage: 14.224 V
    The first fault also notes "MIL ON" (I've never seen that from the other diagnosis systems?), but I'm guessing it could still be a consequence of another fault?
    Any suggestions?
    Audi B7 A4 Avant 2.0TFSIQ aut (241hp, sports susp., valc. leath. sports seats, MF sports steer, navi plus, BOSE, BT, PDC, dyn. bi-xenon, 18" MOMO GT-R)
    BMW 118d (185hp, alu trim, sports int, rain s., navi, MF steer., BT, PDC, 17" M, dual clim., M aerodyn)
    Volvo XC90 (bull bar, side steps, widebody/wheel arch., dual AC, MF steer, 7S, el. leather seats, navi, rain s., phone, prem. aud., bi-xen.+xen. driv. lamps, Webasto, PDC)
  3. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #23
    Aug 2009
    Norway
    I'd also like to mention:
    Lately I've noticed a slight rpm drop at idle every now and then after driving.
    I haven't had a four cyl. petrol car in quite some time (several years), and my other daily driver are a straight six which you can't feel in the car at idle. I know they can't be compared vibration wise, but I still believe the Audi is a bit more rough at idle than it should be. I can feel quite a lot of vibration in the car, but the rpm is stable, other than the noticeable drop which happens once in a while.
  4. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #24
    Oct 2009
    Cleveland, OH
    Your fuel problems sound like classic cam follower issues that we have here in the US. Has your dealer checked the follower?
  5. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #25
    Aug 2009
    Norway
    Wouldn't that cause fuel cuts at high revs?
    And no, I'm pretty sure they haven't checked it. However the cam chain drive was replaced about a year ago. They replaced the following parts:
    06F 198 088 D Repset
    06D 103 469 M Cylinder head cover
    06F 109 217 A Chain tensioner
    06D 109 229 B Camshaft timing chain
    Don't know what the repset includes, but I'm guessing seals etc., not the cam follower...
    Also I've been driving the car like 100 miles the last two days. The vibrations are quite noticeable now, more than before I'm sure. Also there's like a 200-300 rpm drop after idling a few seconds before it comes back up to normal just below the 800 rpm mark...
  6. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #26
    Oct 2009
    Cleveland, OH
    Depending on how bad it is!
    You can pop it out yourself and look, it'll take about 5 minutes and be real obvious if it is bad.
  7. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #27
    Aug 2009
    Norway
    I read up on the TSB around the net and saw people mentioning 1-2 hours, 5 mins sounds better. Found a DIY for a GTI: http://forums.vwvortex.com/zerothread?id=3750088
    I will definitely check mine.
  8. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #28
    Nov 2008
    It certainly isn't 5 mins.
    Getting access to the torx head '****-bolt' (as I call it) or better known as the banjo-bolt in the pump return line. Audi knew this would be an **** to get to and replaced it with a clipped rubber hose in 2007.
    Getting at the feed pipe is a game as well - you can only turn it 1/12th of a turn at a time due to the lack of space to wield a spanner.
    Apart from that its a breeze
    Also see : http://picasaweb.google.com/BJ.McGee...llowerInstall#
    2006 A4 saloon 2.0T S-Line Special Edition.
    Mauritius Blue - Xenons, Bose, Heated Valcona, Cruise, Colour DIS, Ipod, Revo. Big Smile.
  9. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #29
    Aug 2009
    Norway
    The dealer measured fuel pressure and then opened up just to make sure everything looks good, and it does. No noticeable wear at all...
    We had an unhappy meeting with a XC90 on the slippery roads these days so it's in for some painting++ and will be for a week or two. Will get it back to the dealer for the MIL problem after that.
  10. Re: Diagnosis codes, 05 B7 2.0TFSIQ
    #30
    Sep 2007
    London UK
    Hi, Any development on this as mine seems to have the exact same fault
    Audi A4 2.0 TFSi DTM, Quattro, 2006, 220 BHP, Sprint Blue, Multi Spoke Alloys, Light pack, Bi-Directional Xenons, Auto Wipers, Recaro/Electric/Leather/Alcantara/Heated/Memory Seats, Under seat storage, Carbon Fibre spoilers, Carbon Fibre trim inserts, RNS-E Sat Nav, Bluetooth Phone Prep, SDS, FBMFSW, .....
  1. alarm fault codes
    By A6TYY in forum VCDS - Help Requests
    Last Post: 17-08-2009, 08:01 PM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. help w/error codes, 99 2.0L Jetta
    By vwfreak73 in forum Golf MK3 - 1993 - 1999
    Last Post: 03-03-2008, 07:15 PM
  4. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
  5. mk4 gti 2.0, 3 error codes, lean trim, ideas?
    By leckford in forum Golf MK4 - 1999 - 2004
    Last Post: 24-05-2007, 11:57 PM
