Thread: What is an overboost?
  1. What is an overboost?
    Mauritius
    Can someone explain what is an overboost and how it feels like?
    On several occasions, when I try to speed up while in 5th gear, I hear the engine revving up but not a proportional pull from the engine. Is this an overboost?
    thanks
    A4 1.9TDI 130Bhp 2001
  2. Re: What is an overboost?
    Mar 2007
    Lancashire
    Quote Originally Posted by tyberwan View Post
    thanks
    No that's no overboosting. Boosting is all about charge pressure on the turbo. If the car senses and overboost it usually drops into limp mode. Sticking vanes that direct the air onto the turbine don't move quickly enough (due to carbon build up). and then an overboost can occur.
    Your symptoms sound like a slipping clutch but I've only ever known that to happen in low gears where torque is highest. I'm no expert but maybe that is what is happening? Due experience the same in lower gears?
    Marco
    A4 1.9TDI 160bhp Sport - 2001 (51)
    Re-map by more-bhp.
    TT 3.2 V6 DSG quattro 270BHP - 2003 (53)
  3. Re: What is an overboost?
    Mauritius
    No not in lower gears, only in the 5th gear when i am trying to speed up the car, it sounds as if slipping as you said. In lower gears, the car pulls fine.
    thanks
  4. Re: What is an overboost?
    Apr 2007
    Lancashire
    Classic symptom of a slipping clutch.
  1. Overboost 2.5tdi
    By shabazmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-06-2011, 08:38 PM
  2. Asz overboost problem
    By leerobson in forum Golf MK4 - 1999 - 2004
    Last Post: 02-05-2008, 01:27 PM
  3. Turbo Kickback Or Overboost??
    By fasttdi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-03-2008, 01:27 PM
  4. A4 TDI 110 (AFN) Overboost caused by timing
    By ini in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-02-2008, 08:41 PM
  5. A4 1.9 tdi 110 overboost problem
    By eddy_p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-01-2008, 08:05 PM
