Thread: fauilt code 16825 evap canister
  1. fauilt code 16825 evap canister
    Sep 2009
    batley
    1. hi i got this fault code (16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow ) ages back, evap sensor or canistor whateva its called i rang the dealer for the price and they didnt know what it was.
    2. is it the charcoal filter? the black circular unit with two pipes coming out of it below the drivers headlight? if it is i just replaced that yday this time and erased the code light went off everything fine i assumed it was this as when i removed my old one it was making a rattling noise inside as if somethings broken anyways lights just come back on now today after 24 hours
    on ross tech it says
    Possible Solutions
    • Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
      • Perform Output Test
    • Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
      • Perform Basic Setting
    • Check Pipes between Tank Breathing and Throttle Body
    can anyone point out to me where the solenoid valve is located or show me a picture of one plz
    and i assume pipes between tank mean the two pipes on the canister they go to the throttle body??
  2. Re: fauilt code 16825 evap canister
    What is your engine code?
  3. Re: fauilt code 16825 evap canister
    Sep 2009
    batley
    hi thnks 4 replying the engine code is: ALD as far as i can remember will double check tomorow.
    just fitted a solenoid valve i think well anyways replaced this small part with 2 pipes coming out of it one goes to the evap canister and the other pipe goes somewhere under the plastic vw cover reset engine check light and went on a 15 min drive no light yet will see tomorrow
  1. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  2. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  3. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  4. test key code?
    By perfection in forum Audi A3 - Archive Topics
    Last Post: 16-04-2008, 12:12 PM
  5. A3 - leaking fuel - faulty EVAP Canister?
    By brightwell_151 in forum Audi A3 - Archive Topics
    Last Post: 12-02-2008, 12:23 PM
