Thread: Multitronic gearbox
Results 1 to 10 of 13
  1. Multitronic gearbox
    Oct 2009
    Doncaster
    Ive just had a new multitronic gear box ecu and could any body tell me if audi service the gearbox at the same time and do they change the oils and where do you find out what shift your gearbox has my a6 2.5tdi is a 04 plate
  2. Re: Multitronic gearbox
    135 Post(s)
    2026 Post(s)
    They should change the fluid by purging out the system but probably only do a standard fill to keep the cost down. I like to change the filter as well.
  3. Re: Multitronic gearbox
    Oct 2009
    Doncaster
    how many plates do you think my 2.5 tdi v6 have its a 2004 and if it was faulty wouldnt audi tell me that it was faulty when they did the ecu?????
  4. Re: Multitronic gearbox
    135 Post(s)
    2026 Post(s)
    Should be seven disc but if you PM me the cars reg when you get to five posts I can tell you.
  5. Re: Multitronic gearbox
    Oct 2009
    Doncaster
    it is PE04 HLU audi a6 2.5 tdi v6 thanks
  6. Re: Multitronic gearbox
    135 Post(s)
    2026 Post(s)
    It has a GJT code box with a seven plate clutch pack.
  7. Re: Multitronic gearbox
    Oct 2009
    Doncaster
    thanks ps how did you find out so easy ?? thanks
  8. Re: Multitronic gearbox
    135 Post(s)
    2026 Post(s)
    Software I have for work ID’s the car, gives me the chassis number then ETKA (the parts system) I have live with what is called FI suggestion which pin points the parts fitted to your car when new.
  9. Re: Multitronic gearbox
    Oct 2009
    Doncaster
    so its definatly the 7 clutch pack if it is i am so glad
  10. Re: Multitronic gearbox
    135 Post(s)
    2026 Post(s)
    As far as I can tell, yes but they still go wrong.
  1. A6 2.5TDI multitronic - gearbox guaranteed to fail?
    By a6mother in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-04-2012, 11:21 AM
  2. A6 Multitronic Gearbox Problem ?
    By Scottnd in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-10-2009, 03:44 PM
  3. Question 1.9TDi Quattro gearbox R&R
    By gjm123 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-08-2009, 11:47 PM
  4. Help! A4 multitronic gearbox problems!
    By Patsy666 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-04-2008, 10:18 PM
  5. A6 1.8T Multitronic Gearbox Failure
    By Herbiv4 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2007, 08:08 PM
