Thread: XCarlink Annoyance
Results 1 to 10 of 10
  1. XCarlink Annoyance
    Nottingham
    Hi all,
    I have a rcd310 fitted to my golf now, with a xcarlink connected to it.
    It works fine, and did so with the old rcd300 apart from one thing. The old unit had a whistle, this one however does not, it has something more annoying.
    There is a constant high pitched whine/humming that gets higher and faster as the revs/speed increases. Xcarlink support sent me a new lead which has done nothing.
    They then sent me the following response:
    This is an issue with your cars electrical electronic circuitry (Alternator whining) which may be related to the earthing in your car. Relocating the earth connection should resolve this issue, please relocate the earth away from the current earthing position or directly to the battery negative terminal. If this fails you may require a ground loop suppressor.
    Has anyone else suffered this, and have you found a solution. I have had the unit out and re-done the ground connections, but im getting tired of dismanteling the dash.
    Any help would be greatly appreciated.
  2. Re: XCarlink Annoyance
    May 2008
    Quote Originally Posted by tdci115 View Post
    Did you try this?
  3. Re: XCarlink Annoyance
    Nottingham
    If i am honest, no.
    I have no idea what one is, where to get it or where to put it...
    Apologies, i should have said.
  4. Re: XCarlink Annoyance
    May 2008
    Google it, that should solve your issues I would imagine.
  5. Re: XCarlink Annoyance
    Nottingham
    I have done so. All seems interesting. Although they seem to be for amplifiers. Where would one go in the standard setup?
    I can only see ones with RCA connectors, non of which i have.
  6. Re: XCarlink Annoyance
    May 2008
    How about emailing Xcarlink or whoever makes the ipod adapter?? They might even have the exact thing in stock....
  7. Re: XCarlink Annoyance
    Nottingham
    Sadly they have replied, they dont stock such a device.
    Any one have any other ideas?
  8. Re: XCarlink Annoyance
    Feb 2009
    Warrington, Cheshire
    Give this a try ........
    http://www.m-99.co.uk/Car_Audio/Nois...uppressor.html
    Cheers then
    Brian
  9. Re: XCarlink Annoyance
    Manchester, UK
    I have a 'connects 2' aux thingy me bob fitted to a passat with RCD300, when used with a tomtom 910 i get the whine which changes with the revs, however with my nokia 5800 its perrrrfect.
    It is some thing to do with the earthing, however some times tomtom fine other irritating back ground noise, i thought it was the sound of the hard drive spinning but maybe not.
    The answer would be to separate the earth off for your Xcarlink and get a good earth from else where - this should solve the problem
  10. Re: XCarlink Annoyance
    Nottingham
    Hey,
    Had another chat with them and they have asked me to send the unit back. They are replacing it with a unit that has a built in ground loop suppressor, so hopefully should sort it.
  1. XCarlink - MP3 or Ipod?
    By AndyF in forum In Car Entertainment
    Last Post: 08-05-2008, 06:47 PM
  2. iPod, RCD300 and Xcarlink
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-04-2008, 08:32 AM
  3. Xcarlink
    By 1 fatboy in forum Golf MK4 - 1999 - 2004
    Last Post: 14-03-2008, 06:14 PM
