Thread: Check Brake Pads light!
  1. Check Brake Pads light!
    Nov 2008
    Today when i started my car, the check brake pads warning came up on the dash board. The pads on the car are relatively new- the back were done a few months back and the fronts still look like they have half their mileage still left. any suggestions as to what else i can check... Thanks
    Volkswagen Passat Sport 2.0 115bhp
  2. Re: Check Brake Pads light!
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by chrisop View Post
    Did you check both sides of the pads, both inner and outer? The caliper pins can stick, causing uneven wear on either side of the disk.
    Nothing to see here, move along..
  3. Re: Check Brake Pads light!
    Jun 2006
    UK, Mids
    If the discs have a deep lip around the outer edge, this cuts through the pad and into the sensor thus tripping it.
    In summary, the sensor will trip when the pad is down to a depth, plus the depth of this lip.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Check Brake Pads light!
    Nov 2008
    just checked the outside ones but will have a good look tomorrow. the discs look ok and there doesnt appear to be a lip on them. are pads expensive? and do they have those pistons that you have to turn to get them to go in(not too sure of the correct name for them) or do they just push in. should be able to change them myself hopefully lol. done my sisters on her golf a few months ago.
  5. Re: Check Brake Pads light!
    Southern County Softy
    20 Post(s)
    Fronts push in, easy if you loosen the master cylider cap....
    A4 2.5 tdi QS (mapped)
  6. Re: Check Brake Pads light!
    Hampshire
    My warning light kept coming on though the pads were fine. I put it down to the sensors, so I gave the sensors a good wiggling and the light no longer comes on!
  7. Re: Check Brake Pads light!
    Jun 2008
    i had a skoda up with check brake pads light on pads were fine the sensor had come apart whoever changed pads last time broke the wee clip that holds it together so a bit of black tape later everything fine
  1. Question Golf Mk4 GT TDI Rear Wheel Bearing
    By tommi in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2009, 08:21 PM
  2. Bora 2.0i Service Schedule Missing
    By zimbora in forum Bora - 1998 - 2005
    Last Post: 10-04-2008, 11:45 PM
  3. Polo brake light fuse problem
    By iandy in forum Polo - Derby - Lupo - Fox
    Last Post: 09-04-2008, 02:12 PM
  4. Check Brake Pads Warning
    By Caribbeanwind in forum Passat - Archive Topics
    Last Post: 28-04-2007, 12:59 PM
  5. Audi A4 Brake light problem
    By agriffiths in forum Archive posts
    Last Post: 22-12-2006, 02:10 PM
