Thread: Electric Window Gremlins
  1. Electric Window Gremlins
    Jul 2006
    Hi Guys,
    My wifes 2005 A3 sportback (2.0 tdi) has developed a mind of its own! Wife leaves car locked and secured and returns after work to find all windows open!
    This has happened twice now in the space of a couple of weeks. She is unsure if the locks were also open. She assures me its not a case of inadvertently pressing the remote fob!
    Can anyone give any pointers as to where to start the investigation?
    thank you
  2. Re: Electric Window Gremlins
    Jul 2006
    Anyone able to shed any light, no fault codes stored on car.
  3. Re: Electric Window Gremlins
    Jun 2008
    Leics
    Maybe , if you've got a 'spare' key you could get the missus to use that for one day to narrow down whether the key is at fault?
    Audi A3 2.0 FSI '53 plate, in Akoya Silver
  4. Re: Electric Window Gremlins
    May 2007
    knee deep in clunge
    14 Post(s)
    Possible cause.
    Remote accidently pressed within the range of the vehicle or water accross the terminals causing a resisitive circuit.
    Easy solution, code out total window closure function
  5. Re: Electric Window Gremlins
    Bournemouth
    Quote Originally Posted by a8 tech View Post
    Possible cause.
    Exactly the same as my wifes 2005 Golf Mk V 2.0 GT TDI. It has happened twice - both times in the rain but several months between (most recently 2 days ago - when it became a problem not a blip)
    Not sure how disabling total closure function relates to total opening problem
    If you could expand on this A8 Tech that would be great.
  6. Re: Electric Window Gremlins
    May 2007
    knee deep in clunge
    14 Post(s)
    Total closure controls the convenience function to open/close all the window via holding the key in the locked position/unlocked for 10 seconds, also pressing the remote open/close.
    If you code out the function the windows will not drop and further coding to single door unlock.Its a quick fix until further investigation can be carried out but most causes are operator error or resistive circuits/door control units.This is a suggestion not a solution
  1. Golf mk3 electric window problem
    By iaindhill in forum Golf MK3 - 1993 - 1999
    Last Post: 21-03-2010, 05:07 PM
  2. The Audi e-tron
    Last Post: 02-10-2009, 07:30 AM
  3. The Audi e-tron
    Last Post: 15-09-2009, 08:34 PM
  4. Polo 6N2 electric window fault
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2008, 10:11 AM
  5. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
