Thread: Fix my clutch
Results 1 to 10 of 14
  1. Fix my clutch
    May 2009
    Nelspuit,South Africa
    A repute service centre fitted my clutch kit but could not sort out one problem. I have to floor my pedal all the way down to get gear change. Fitted a new slave cylinder. Pleas help anyone ?
  2. Re: Fix my clutch
    Canada
    Quote Originally Posted by BenJeeD View Post
    they would have hard job fitting a new slave cylinder, it doesn't have one. the thrust bearing and hydraulics are one unit.
  3. Re: Fix my clutch
    May 2009
    Quote Originally Posted by onzarob View Post
    Hi Mate
    Pardon my ignorence, whats the unite just be hind the pedal is that not a slave. Well they clain i was cracked and linking brake fluid. but with all the bleeding done my pedal stil sticks and has a play
  4. Re: Fix my clutch
    Up North
    If it's directly behind the pedal and it's hydraulic, then it is a master cylinder. I didn't realise Golf's have a hydraulic clutch, I assumed they were a cable like on the Polo (mine's a DSG).
    If they have fitted a complete new clutch with bearing and a master cylinder too the only remaining (and highly unlikely) option is that the pedal is bent or dodgy in some other way. I've also had similar before when the wrong clutch was fitted but there's no chance of this at a "reputable" firm. Best bet is to go back and tell them to sort it out whatever they have done wrong.
    Was the problem there before? Does it go away if you pump the pedal? Are you losing hydraulic fluid?
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  5. Re: Fix my clutch
    131 Post(s)
    1974 Post(s)
    Which engine and box?
  6. Re: Fix my clutch
    May 2009
    This a 1.9 TDI 77kw BKC 5 speed box
  7. Re: Fix my clutch
    May 2009
    Quote Originally Posted by Teflon View Post
    Yes the problem was there berfore and after new clutch kit an master cylinder fitting the pedal issue was still there. Im not loosing any fluid. Could it be an issue of poor quality fluid, they used 4 dot 1?. I have not tried to pump the pedal but its kinda like intermitted...sometimes its works normal. Most times its returns just sec later, yet it disagange gears when pedal is 90% depressed.
  8. Re: Fix my clutch
    131 Post(s)
    1974 Post(s)
    Ben when you have made 5 posts, can you send me the chassis number by private Message and I can look at the cars specific parts? Can you find out exactly which parts have been replaced? Preferably their part numbers if at all possible.
  9. Re: Fix my clutch
    May 2009
    Guys i have had a futher look at my car and found that i have one cylinder just be hind the pedal and one attached to the box which makes it a maste ..right? Could it be that i need a new master cylinder. I plan to run out all the brake fluid to put a fresh high quality fluid be for i fit a new master cylinder since i have a new slave.
  10. Re: Fix my clutch
    131 Post(s)
    1974 Post(s)
    In my experience, changing the fluid is likely to make it worse as the new fluid is thinner. If you have a new slave cylinder (the one in the box) then I suggest you fit a new master cylinder and then bleed the system.
  1. Air Con Compressor Clutch Fell Off
    By mystic.bertie in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-09-2009, 09:55 PM
  2. Clutch Noise - Advice Needed
    By Timk in forum 80 - 90
    Last Post: 27-03-2009, 08:12 PM
  3. Clutch Pedal Judder
    By macker6464 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-03-2009, 10:45 PM
  4. Shafted....really?
    By Martin Burnard in forum Chat - Anything with wheels
    Last Post: 04-02-2008, 09:44 PM
  5. Replies: 2
    Last Post: 11-05-2007, 12:30 PM
