Thread: Touran Headlamp Washers / Fuse
  1. Touran Headlamp Washers / Fuse
    Mar 2010
    newcastle
    I have a 2005 Touran 2.0 TDI, the headlamp washers have stopped working altogether, they dont even pop out
    Can anyone please tell me where to try? The manual makes no reference to the fuse location?
    Many Thanks
  2. Re: Touran Headlamp Washers / Fuse
    May 2007
    17 Post(s)
    Hey there. The Touran headlamp washers are powered via fuse 53 (20Amp) on the dash fusebox. That's one of the larger fuses, bottom row 6th fuse in from the right. If you look closely you'll see the fuse numbers marked on the box.
    There is also a relay in the circuit. It's located on the relay plate behind the dash on the drivers side. It has spaces on it for 9 relays although they don't all have relays fitted. I think the one for the lamp washers is at the center left position and should be marked with a number 53.
    I hope that helps.
    Regards - Jim.
  3. Re: Touran Headlamp Washers / Fuse
    Mar 2010
    newcastle
    Jim, That has worked a treat. Many Thanks!!!!!!!
  1. Question Airbag fuse
    By pcplum in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2010, 06:57 PM
  2. polo 2001 1.0e fitting headlamp washers??
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 15-02-2010, 09:42 PM
  3. Touran fuse box
    By nickatwharf in forum Touran - Sharan - Caravelle
    Last Post: 11-03-2008, 09:01 PM
  4. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
  5. FIRST PICTURES OF NEW TOURAN REVEALED BEFORE PARIS SHOW
    Last Post: 13-09-2006, 07:14 PM
